Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    Construction
    AutoCAD 2018
    Nov 2017
    47
    Angry Cannot find definition for dialog
    Can somebody help me this problem?
    I have both the lisp file and the dcl file in the Autocad search path. I have many other lisp & dcl files in the same folder and they all work fine.
    This one is very stubborn. I just can't figure it out.
    The lisp file is called "weld1.lsp" and the dcl file is called "Welds1.dcl"
    Code:
    weld1 : dialog {
          label = "WELD NOTES 1 " ;
          : row {
          label = "WELD SIZE";
          : row {
              : edit_box {
                key = "dws";
                edit_width = 6;
                alignment = left ;
      ok_cancel ;
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,271
    Hi,
    Copy the following in the command line in AutoCAD and let me know what would that returns.
    Code:
    (findfile "Welds1.dcl")
    Senior Member
    Surveying
    dlanorh's Discipline Details
    Geospatial Engineer
    Surveying
    AutoCAD 2012
    Aug 2017
    UK/Bundesrepublik Deutschland
    136
    Can't see anything wrong with the dcl file
    Check the lisp file is loading "Welds1.dcl" and loading dialog "weld1". I normally call my dialog the same as the dcl file, otherwise it's easy to make a mistake and nothing appears to happen. Without seeing the lisp code relating to loading and setting the dialog i can't diagnose if there is a problem with the code. I always use the following
    Code:
    (setq d_name (vl-filename-base dcl_name))
     (if (not (setq dcl_id (load_dialog dcl_name))) (alert (strcat "Cannot Find DCL file : " dcl_name)))
     (if (not (new_dialog d_name dcl_id)) (alert (strcat "Cannot Start DCL dialog : " d_name)))
    where dcl_name is the *.dcl file
    Full Member
    Construction
    AutoCAD 2018
    Nov 2017
    47
    Code:
    Command: (findfile "Welds1.dcl")
    "C:\\Users\\ynotsbbig\\#advance\\delta tools\\Welds1.dcl"
    Here is the lisp:
    Code:
    (defun C:weld1 (d1 ddiag dcl_id p1)
       (defun setVars()
          (setq d1 (distof (get_tile "dws"))))
          (setq dcl_id (load_dialog "Welds1.dcl"))
       (if (not (new_dialog "Welds1" dcl_id))
          (exit)
          (action_tile "accept" " (setVars)(done_dialog 1)")
          (action_tile "cancel" "(done_dialog 0)")
          (setq ddiag (start_dialog))
       (if (= ddiag 1)
            (setq p1 (getpoint "\nPick a point "))
            (command "_line" p1 (polar p1 (deltadtr 0) dws))
         (unload_dialog dcl_id)
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,106
    Code:
    Code:
     (new_dialog "weld1" dcl_id)
    deltadtr -> defun?
    dws in polar function is d1?
  6. #6
    Senior Member
    Surveying
    Geospatial Engineer
    Surveying
    AutoCAD 2012
    Aug 2017
    136
    Change your lisp as per rlx or
    Code:
    Welds1 : dialog {
          : row {
          : row {
              : edit_box {
                key = "dws";
                edit_width = 6;
                alignment = left ;
      ok_cancel ;
  7. #7
    Full Member
    Construction
    AutoCAD 2018
    Nov 2017
    47
    Ive now renamed both the lisp and the dcl files to "weld1"
    I'm still struggling with it.
    This is the lisp:
    Code:
       (defun setVars()
          (setq dcl_id (load_dialog "weld1.dcl"))
       (if (not (new_dialog "weld1" dcl_id))
          (exit)
       (if (= ddiag 1)
            (command "_line" p1 (polar p1 (deltadtr 0) d1))
    This is the dcl:
    Code:
    weld1 : dialog {
          : row {
          : row {
              : edit_box {
                key = "dws";
                edit_width = 6;
                alignment = left ;
      ok_cancel ;
  8. #8
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    Code:
    (defun C:weld1 ( / dcl-fn dcl-fp dcl-id ddiag d1 p1)
      (mk_dia)
      (if (and (setq dcl-id (load_dialog dcl-fn)) (new_dialog "weld1" dcl-id))
          (vl-file-delete dcl-fn)
          (action_tile "accept" "(setq d1 (distof (get_tile \"dws\")))(done_dialog 1)")
          (unload_dialog dcl-id)
          (cond
     ((= ddiag 1)
      (command "_line" p1 (polar p1 (deltadtr 0) d1))); deltadtr = ? , dws = d1?
    (defun deltadtr (i) (if i i 0))
    (defun mk_dia ()
      (if (and (setq dcl-fn (vl-filename-mktemp ".dcl")) (setq dcl-fp (open dcl-fn "w")))
        (mapcar '(lambda (x)(write-line x dcl-fp))
         '("weld1:dialog{label=\"WELD NOTES 1\";:row{label=\"WELD SIZE\";:row {"
           ":edit_box{key=\"dws\";label=\"WELD SIZE\";edit_width=6;alignment=left;}}}ok_cancel;}")))
      (if dcl-fp (close dcl-fp))(gc)
    ;(C:weld1)
  9. #9
    Full Member
    Construction
    AutoCAD 2018
    Nov 2017
    47
    Thanks RLX.
    Its obvious to me that you are a lot smarter than me at lisp. The one you sent me works really well.
    In saying that, is it possible to look at my much simpler version because I have many other dcl and lisps that I have written and they are all much the same style.
    I can understand my style as I am familiar with it.
    By the way "deltadtr" is a local lisp I have for Degrees to Radians. It works fine.
    Thanks
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    Quote Originally Posted by TunzaGibbo View Post
    Thanks RLX.
    Thanks
    Code:
    (defun c:weld1 ( /  ddiag dcl_id p1 d1)
      (defun deltadtr (a) (* pi (/ a 180.0)))
      (setq dcl_id (load_dialog (findfile "weld1.dcl")))
      (if (not (new_dialog "weld1" dcl_id))(exit))
      (action_tile "dws" "(setq d1 (distof (get_tile \"dws\")))")
      (action_tile "accept" "(done_dialog 1)")
      (if (= ddiag 1)
          (command-s "_line" p1 (polar p1 (deltadtr 0) d1))
    think command-s does the trick and action-tile editbox can (should) be
    Code:
     (action_tile "dws" "(setq d1 (distof $value))")
  1. DCL dialog box that modifies a nested dialog box...
    By sethtriad in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Feb 2013, 01:30 pm
  2. Find and Replace without dialog
    By paulfillion in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2013, 04:41 pm
  3. Find and replace text without a dialog box
    By y49sides in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jan 2012, 03:34 pm
  4. FIND command without dialog box?
    By NoelStalker in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Nov 2009, 03:12 pm
  5. Find/Replace text without a dialog box?
    By y49sides in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jul 2009, 11:43 pm
