AdamW Posted May 13, 2018 Share Posted May 13, 2018 Does anyone have any ideas? Ive just had a new dell pc i7 core running windows 10 with 16Gb of ram a SSD hard drive and an NVidia graphics card (4 or 8gb from memory). Im running AutoCAD 2015. Everything was fine for the first two weeks. Now when i select a hatch AutoCAD crashes. I can create a hatch no problems just cant select it afterwards. I can select it with another item say a line. with no issues. Ive tried the following. 1. Turning off hardware acceleration in 3DConfig 2. Setting Hpscale to 10 from 1 3. Setting Hpqucickpreview to Off 4.Updating the NVidia graphics card 5.Disabling all lisps I have from loading at startup. Looking on the net some say it is lack of system recources but I dont think that could be my problem due to the spec of the pc. Only thing I can think of is to reset my profile to AutoCAD default, but I am a bit reluctant to do this. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 14, 2018 Share Posted May 14, 2018 AutoCAD 2016 with a service pack was the first AutoCAD for Windows 10. You may need to find a tweak somewhere. Are you running in compatibility mode? Restore Windows back to before you started having the problem, might work. What Graphics card are you using? The latest driver may not be the best one in your situation. Quote Link to comment Share on other sites More sharing options...
