+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2016
    Join Date
    May 2018
    Posts
    1
    Default New to Parametric settings question
    Hello everyone,
    I am new to the parametrics concept, I used to draw only 2d basic stuff.
    I have been asked to make a drawing from a PDF sketch as follows: " i need ALL plans as Parametric / Autocad Architecture"
    I don´t know exactly what is meant by "parametric" if someone out there could guide me please, thanks so much!
    ..m
  2. #2
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,506
    Default
    Autocad architecture was the pre version of REVIT using parametrics, so parametric may be referring to say a door has 2 variables a height and width. Two parametrics, change the value the door changes. You need to go back and clarify with who is asking a big task if starting form scratch.
  3. #3
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    6,045
    Default
    A parameter can be just about anything you want it to be, you just need to define it, or them.
    Color, Height, Width, Weight & Handing (meaning Left or Right), are a few examples.
    In Parametric work, there are preconditions (Parameters) applied, wherever they might be helpful or needed, which constrain the relationships between different elements in the design. Perhaps Circles need to maintain Concentricity, or a given distance between centers, which might be triggered by the Radii of the Circles.
    It is very interesting, and a bit of a rabbit hole/slippery slope, as it is so powerful.
    Volume and repetition do not validate opinions forged in the absence of thought.
Similar Threads
  1. Parametric Block Settings Database
    By Kemphas in forum Electrical
    Last Post: 28th Aug 2015, 10:30 pm
  2. Autocad settings question
    By Folio in forum AutoCAD General
    Last Post: 30th Mar 2012, 12:44 am
  3. Question about render settings
    By bastymydawg in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Jun 2010, 06:05 pm
  4. Tool bar settings and profiles question
    By JayT in forum CAD Management
    Last Post: 11th Apr 2008, 06:09 pm
  5. Question about zoom/pan settings
    By FiRoy in forum AutoCAD General
    Last Post: 2nd Aug 2006, 11:43 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
