bkartal16 Posted May 15, 2018 Share Posted May 15, 2018 hi all, i have drawings that contains stations and waterlines as polyline or spline. (in att. dwg named as ST0, ST1...ST20, and WL0 to WL8) there may be other stations or waterlines such as ST0.5, ST1.5, WL9, WL10... i need a table that shows distance of intersection points from CL. (see att. dwg) is it possible to make this table by lisp? lines.dwg Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted May 15, 2018 Share Posted May 15, 2018 (edited) Suggestion: make all layers unique for each (section) lwpolyline, i.e: "ST0" "ST1" "ST10" etc.. otherwise we can't populate the intersection points if all sections are in same layer "ST17" ?! (vl-load-come) [color="green"];Rev 1[/color] (defun c:[b]test1[/b] (/ *error* p ss lst fn f [color="red"]hp:table[/color] ) [color="green"];<-- localize=output csv, global=output table, i.e: To remove [color="red"]hp:table[/color] from variable list[/color] ;hanhphuc 15.05.2018 (defun *error* (msg) (if f (close f) ) ) (if (and (setq p (getpoint "\nSpecify base point.. ")) (setq ss (ssget '((0 . "LWPOLYLINE") (8 . "[color="purple"][b]GRID,*ST*[/b][/color]")))) (setq lst (mapcar ''((x) (setq obj (vlax-ename->vla-object x)) (cons (vla-get-Layer obj) (reverse (mapcar ''((a / ip) (if (setq ip (vlax-invoke obj 'intersectwith (vlax-ename->vla-object a) AcExtendNone)) (rtos (* (-(car (trans ip 0 1))(car p)) 1e-3) 2 3) "-" ) ) (vl-remove-if ''((x)(or (apply 'equal (append (mapcar ''((f) (car (trans ( f x ) 0 1 ))) (list vlax-curve-getstartpoint vlax-curve-getEndpoint)) '(1e-3)) ) (not (wcmatch (cdr(assoc 8 (entget x))) [b][color="purple"]"GRID"[/color][/b]) ) ) ) (acet-ss-to-list ss)) ) ) ) ) (vl-remove-if-not ''((x)(wcmatch (cdr(assoc 8 (entget x))) [color="purple"][b]"*ST*"[/b][/color] )) (acet-ss-to-list ss)) ) ) (setq lst (cons '([b][color="purple"]"SECTIONS" "WL0.0" "WL0.5" "WL1.0" "WL2.0" "WL3.0" "WL4.0" "WL5.0" "WL6.0" "WL7.0" "WL8.0"[/color][/b]) (vl-sort lst ''((a b) (apply '< (mapcar ''((x) (car ([color="blue"]LM:parsenumbers[/color] x))) (list (car a) (car b)))))) ) ) ); and (if (and hp:table (setq p (getpoint "\nSpecify insertion point.. "))) (hp:table lst (trans p 1 0) "OFFSET TABLE" (getvar 'textsize)) (progn (and (setq fn (vl-filename-mktemp "tmp" (getvar 'dwgprefix) ".csv")) (setq f (open fn "w")) (foreach x lst (write-line (apply 'strcat (mapcar ''((a) (strcat a ",")) x)) f)) (progn (if f (close f) ) (vl-cmdf "start" fn) ) ) ) ); if (princ "\nNothing!") ) (princ) ) ;_ end of defun [color="green"] ;; Parse Numbers - Lee Mac ;; Parses a list of numerical values from a supplied string.[/color] (defun LM:parsenumbers ( str ) ( (lambda ( l ) (read (strcat "(" (vl-list->string (mapcar '(lambda ( a b c ) (if (or (< 47 b 58) (and (= 45 b) (< 47 c 58) (not (< 47 a 58))) (and (= 46 b) (< 47 a 58) (< 47 c 58)) ) b 32 ) ) (cons nil l) l (append (cdr l) '(())) ) ) ")" ) ) ) (vl-string->list str) ) ) This routine is only a test on drawing you provided, i.e. you need to modify the TEXTSIZE to suit your drawing Command: TEXTSIZE then edit new value 200.0 or add (setvar 'textsize 200.) as default in the code Edited May 18, 2018 by hanhphuc rev1, allow pick base point Quote Link to comment Share on other sites More sharing options...
bkartal16 Posted May 16, 2018 Author Share Posted May 16, 2018 hi hanhphuc, thnx for great code and suggestion. really fast job. but i think something missing about "hp:table" that i dont have. so the code gives me only temp001.csv file. can u fix this? Quote Link to comment Share on other sites More sharing options...
bkartal16 Posted May 18, 2018 Author Share Posted May 18, 2018 is there another way to make autocad table from the csv file? Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted May 18, 2018 Share Posted May 18, 2018 hi hanhphuc, thnx for great code and suggestion. really fast job. but i think something missing about "hp:table" that i dont have. so the code gives me only temp001.csv file. can u fix this? hi, actually you can direct copy from .csv then paste as OLE object in ACAD. This forum as we are volunteers , we prefer OP attempt to code & solve it, sometimes busy may overlook. it was external global function omitted, so should be unique name (defun hp:TABLE ( lst pt str sz / obj r i ) ;hanhphuc [color="green"];RetVal = object.AddTable(InsertionPoint, NumRows, NumColumns, RowHeight, ColWidth) [/color] (setq obj (vlax-invoke ((lambda (doc) (foreach x '(ActiveDocument ActiveLayout Block) (setq doc (vlax-get doc x))) ) (vlax-get-acad-object) ) 'AddTable pt ; InsertionPoint (if str (+ 1 (length lst)) ; NumRows (length lst) ) (length (car lst)) ; NumColumns (* sz 3.0) ; RowHeight (* sz 10.) ; ColWidth ) ) (foreach x (list acTitleRow acHeaderRow acDataRow) (vla-settextheight obj x sz) (vla-settextStyle obj x (getvar 'textStyle)) ) (setq r (if str (progn (vla-settext obj 0 0 str) 1 ) 0 ) ) (foreach x lst (setq i 0) (foreach $ x (vla-setcellalignment obj r i acMiddleCenter) (vla-settext obj r i $) (setq i (1+ i)) ) ;_ end of foreach (setq r (1+ r)) ) ;_ end of foreach (vla-put-regeneratetablesuppressed obj :vlax-false) obj ) ;_ end of defun Here's another workaround 1.pick base point at zero axis 2.select crossing or window 3.Insert table Quote Link to comment Share on other sites More sharing options...
bkartal16 Posted May 21, 2018 Author Share Posted May 21, 2018 thank you very much hanhphuc, this is really great Quote Link to comment Share on other sites More sharing options...
