Results 1 to 2 of 2
    Super Member
    Sengna's Computer Details
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    537
    Default External reference didn't show up after reload Autocad 2017
    I have a main drawing that Xref to other drawing, when i opened the main drawing, the message showed"one or more reference files could not be located or read. what do you want to do? so i clicked on UPDATE THE LOCATION OF THE REF files, after it was opened the screen was blank, i click reloaded the Xref but nothing show up, how can i solve the issue, the xref file is not being moved from original location
    (note)
    i don't want to detach the file yet because if i have to start from sketch i might put in the wrong datum point.
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    537
    never mind, i found this solution, on the Xref manager, at the bottom on detail, i clicked the file path and reload from there, everything appear now.
  1. Reload / Update linetypes in AutoCAD 2017
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 27th Feb 2017, 08:10 pm
  2. Section called out didn't show on the paperspace??? Autocad 2014
    By Sengna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Dec 2014, 05:07 pm
  3. LTS/Dash lines didn't show on paperspace!!!!
    Last Post: 2nd Oct 2013, 09:32 pm
  4. The new External Reference tools you didnt know about in AutoCAD 2014
    By The CAD Geek Blog in forum AutoCAD RSS Feeds
    Last Post: 27th Jun 2013, 11:50 pm
  5. External Reference Enhancements in AutoCAD 2012
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 8th Aug 2011, 04:30 pm
Tags for this Thread
