Results 1 to 8 of 8
Thread: hatch dxf group
    Senior Member
    Architectural
    svorgodne's Discipline Details
    Architect. Lisp developer
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    150
    Default hatch dxf group
    hello everyone,
    what is the dxf group for a hatch that was generated from an opened polyline?
    Thanks in advance
    Senior Member
    Architectural
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    150
    Found it... thanks anyways
    (93 . 4) --> generated from a closed polyline
    (93 . 6) --> generated from a opened polyline
    This might be helpful
    Code:
    (setq cmdecho (getvar 'CMDECHO))
    (setvar 'CMDECHO 0)
    (setq SYM_SelectionSet (car (entsel)))
    (setq LST_DataEntity (entget SYM_SelectionSet))
    (initget 1 "One All")
    (setq SYM_Methode
      (getkword
        "\nDo you want to...? [One/All]: "
    (cond
        (= SYM_Methode "One")
        (setq SYM_DXFGroup
          (getstring
            "\nEnter DXF Group Number: "
        (princ
          (assoc (atoi SYM_DXFGroup) LST_DataEntity)
        (mapcar
          '(lambda (SYM_Member)
            (print (assoc SYM_Member LST_DataEntity))
          LST_DataEntity
        (= SYM_Methode "All")
        (foreach miembro LST_DataEntity
          (print miembro)
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    I think you are mistaken: DXF group 93 stores the number of edges in the hatch boundary or number of vertices in a polyline hatch boundary.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    Architectural
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    150
    Thanks as always dear Lee.
    What would be then the DXF group that identifies if a hatch was generated from an open polyline?
    Thanks in advance
  5. #5
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    963
    Not really my area of expertise but did a little test and noticed that a hatch from a closed polyline has an area and the open one has not... so....
    Code:
    (defun c:t1 ( / e )
      (if (and (setq e (car (entsel))) (= (cdr (assoc 0 (entget e))) "HATCH"))
        (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-Area  (list (vlax-ename->vla-object e))))
          (princ "\nHatch created by open poly")
          (princ "\nHatch created by closed poly")
        (princ "\nNothing selected or object was not a Hatch")
    maybe it works , maybe not...
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    Quote Originally Posted by svorgodne View Post
    I don't believe there is a specific DXF group which will provide this information.
    Quote Originally Posted by rlx View Post
    A good suggestion, however, the area property will also return an error if the hatch has a self-intersecting boundary, therefore this may return false-positives.
  7. #7
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    963
    Quote Originally Posted by Lee Mac View Post
    Looking on the bright side of things : learned something new this day :-) thanx for the info
    one way of finding the bad ones :
    Code:
    ; http://www.theswamp.org/index.php?topic=44532.0
    (defun c:HatchAreas (/ AREA CNT OBJ OBJVL ORC SSET )
      (defun NLayer (Nme)
        (if (not (tblsearch "LAYER" Nme))
          (progn (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord")
           (cons 100 "AcDbLayerTableRecord") (cons 2  Nme) (cons 70 0) (cons 62 1))))))
      (nlayer "HatchHasNoArea")
      (if (>= (atof (substr (getvar "acadver") 1 4)) 16.2)
          (prompt "\nSelect hatches: ")
          (if (and (setq sset (ssget '((0 . "hatch"))) cnt 0 area 0))
       (repeat (sslength sset)
         (setq obj   (ssname sset cnt))
         (setq objvl (vlax-ename->vla-object obj))
        (vl-catch-all-apply 'vla-get-area (list objvl)))
           (progn (vla-put-color objvl 256)(vla-put-layer objvl "HatchHasNoArea")) ;prgn
           (setq area (+ area (vla-get-area objvl)))
           ) ;if
         (setq cnt (1+ cnt))
       ) ; repeat
          ) ;if
      ) ; if
      (alert
        (strcat
          "\nTotal area = "
          (if (or (= (getvar "lunits") 3) (= (getvar "lunits") 4))
     (strcat (rtos area 2) " sq. in. (" (rtos (/ area 144) 2) " sq. ft.)"
      "\nHatchs with RED color DID NOT calculated")
     (strcat (rtos area) "\nHatchs with RED color DID NOT calculated"))
        ) ; strcat
      ) ;alert
    ) ; defun
  8. #8
    Super Member
    not applicable
    Jun 2016
    669
    If the hatch is associative you can check the boundary loop:
    Code:
    (defun c:HatchLwPolyBoundaryClosed_P ( / elst enm)
      (and
        (setq enm (car (entsel "\nSelect hatch: ")))
        (setq elst (entget enm))
        (vl-position '(0 . "HATCH") elst)
        (or
          (setq elst (member '(97 . 1) elst)) ; Remove first gc 330 items and check for single boundary loop.
          (prompt "\nError: more than one boundary entity ")
        (setq enm (cdr (assoc 330 elst))) ; Ename of loop.
        (or
          (vl-position '(0 . "LWPOLYLINE") elst)
          (prompt "\nError: not an LWPOLYLINE ")
        (= (logand (cdr (assoc 70 elst)) 1) 1)
    BricsCAD 18
  1. Changing a hatch pattern scale, from a solid hatch
    By CesarA in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jan 2016, 04:25 pm
  2. Replies: 14
    Last Post: 21st Jan 2015, 06:23 am
  3. Acts like a group but NOT a group
    By Florida John in forum 3D Modelling
    Last Post: 8th Jul 2012, 06:07 pm
  4. Lisp or codes to explode group of entities (gathered by GROUP command)
    By Sweety in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Dec 2010, 03:19 pm
  5. Printing PDFs / JPGs - hatch / super hatch errors
    By busseynova in forum AutoCAD Drawing Management & Output
    Last Post: 20th Mar 2010, 02:12 pm
