Results 1 to 5 of 5
    Senior Member
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    488
    Default Points of leader
    Code:
    (setq pt(nentsel (strcat "\n Select a leader  < exit > : ")));get entity
    (setq e (entget (car pt)));;association list of entity
    (setq p1 (assoc 10 e))
    How can I get 3 points of leader.
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    808
    Use the lisp function MEMBER It searches a list for an occurrence of an expression and returns the remainder of the list, starting with the first occurrence of the expression so:
    Code:
    (defun C:test (/ e pt p2 p3)
    	      e (entget (car pt));;association list of entity
    	      e (member (assoc 10 e) e)
    	      p1 (cdr (assoc 10 e));; cdr removes the 10 leaving the coordinates.
    	      e (cdr e)
    	      p2 (cdr (assoc 10 e))
    	      e (cdr e)
    	      p3 (cdr (assoc 10 e))
            (princ "\np1=")(princ p1)(princ ", p2=")(princ p2)(princ ", p3=")(princ p3)(princ)
    should return what you're looking for.
    You may want to search for qlset.lsp by Frank Whaley who worked for Autodesk. This code allows you to examine the current QLEADER settings, or to initialize the setting before using the QLEADER command. It can tell you how many points the leader has for example. Not everyone uses the default settings.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,447
    First define a function that will check for that group code key, and return its value:
    Code:
    (defun IsItDxf10 ( x )
      (if (= (car x) 10) (cdr x))
    Second learn how to use vl-remove-if-not function to retrieve the items from the list that match the function's criteria.
    Assuming that you know the dxf elist is obtained via (entget <ename>).
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    Use a method similar to that which I describe here.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    488
    Thanks all fore helping me.
  1. Variable to set number of points in a Leader
    By rubio_jose in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Oct 2017, 09:19 pm
  2. Leader to Multi-Leader and auto attaching with closet Dtext or Mtext
    By kite15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Mar 2016, 10:08 am
  3. Leader annotation bind to leader
    By wimal in forum AutoCAD General
    Last Post: 15th Jul 2013, 07:35 am
  4. LISP for Room Size 2 horizontal points & 2 vertical points
    By nihar in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jan 2013, 02:53 am
  5. Replies: 0
    Last Post: 5th Apr 2012, 08:15 pm
