Results 1 to 9 of 9
    Senior Member kippax's Avatar
    AutoCAD LT 2015
    Jul 2007
    Manchester, UK
    181
    Default Linetype Scale Headache
    In a couple of instances I have had to adjust the linetype scale to 200 to get a line to appear as dashed.
    On the working base it looks fine, on the L2 it looks fine, however on the L3 it appears solid, both in model and paperspace ... I have tried
    MSLTSCALE=1
    PSLTSCALE=1
    To no effect.
    Any ideas.
    Senior Member pendean's Avatar
    pendean's Computer Details
    Windows 10 64it Pro
    Lenovo WorkStation
    Architectural
    AutoCAD 2018
    Jun 2011
    Texas
    101
    Post your problem DWG file as well as the "just fine" dwg file, or snippets of them with the problem shown, lets all have a look for ourselves.
    Dean Saadallah
    AutoCAD and LT User
    BLOG|TW|FB|PIN
    Full Member
    Handiman's Computer Details
    (W) Win 10, x64 / (H) Win 7 Prof. x64
    (W) Custom / (H) Custom i5
    (W) Asus X99-A II / (H) ASUS P8Z7- V Pro
    (W) i7-6800K (H) i5-3570K
    (W) 32GB (H) 32GB
    (W) GTX-1070 (H) Quadro K4000 & GeForce 660ti
    (W) 950 Pro 512GB SSD (H) 256GB, 60GB SSD's
    (W) 850 Pro SSD, 1TB platter (H) 3 TB 7200Rrpms
    (W) Dual ASUS 27" (H) Dual ASUS 27" MX-279H
    Manufacture
    Handiman's Discipline Details
    Detailing/Designing Stair handrails, Illuminated & Non-Illuminated
    Manufacture
    Handrails for Commercial and Residential Illuminated and Non-Illuminated (LED mostly)
    AutoCAD 2018
    May 2012
    Dallas TX
    98
    Try PSLTSCALE = 0 on each page. You must activate on each page or the pages you want it to be the same.
    That will have the same Paper Space Line Scale as your Model Space Line Scale.
    Also try REGEN to get the line to update.
    Without an example file to test we are all guessing.
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    802
    Make sure Visual Style is set to 2D Wireframe.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  5. #5
    AutoCAD LT 2015
    Jul 2007
    Manchester, UK
    181
    OK.... so the drawing sequence is (Model Space) WB > D2 > (Paper Space) D3.
    The lines in question are the centre-lines for the building bays and they appear dashed until we get to the D3.
    Many thanks.
  6. #6
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    802
    The Paper Space viewport scale is 1:100.
    With MSLTSCALE=1 & PSLTSCALE=1 if you change the scale of WB.dwg from 1:1 to 1:100 the lines will appear solid in that drawing as well.
    That's just how linetypes work.
  7. #7
    AutoCAD LT 2015
    Jul 2007
    Manchester, UK
    181
    Any ideas ?
  8. #8
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    802
    Quote Originally Posted by kippax View Post
    Any ideas ?
    Change the LTSCALE for D3.dwg to 0.01
    Better yet change the scale in WB.dwg to 1:100 and find a linetype that works, you will probably need it on your next drawing as well.
  9. #9
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    320
    My mind hurts.... All those linetype scales...
    All i use is 'MSLTSCALE' set to '0' in modelspace and on each paperspace i use 'PSLTSCALE' set to '0'. Using a global 'LTSCALE' of '1' all i have to do is set the linetypescale in the properties of the line to get what i want.
    Setting both 'MSLTSCALE' and 'PSLTSCALE' to 0 makes sure that the linetypescale used in the modelspace is the same in the paperspace (proportional to the viewportscale).
    Please don't hassle with any kind of other linetype scale system variables, it makes life so much easier when its the same scale in every situation....
  1. Linetype macro with Linetype Scale
    By Fierce12 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 13th Feb 2015, 08:02 pm
  2. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  3. linetype scale
    By rookie37 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jun 2008, 03:30 am
  4. Linetype and Linetype Scale!
    By Penfold in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2007, 11:45 pm
  5. Scaling linetype scale with SCALE command?
    By SpeedDemon in forum AutoCAD General
    Last Post: 23rd Jul 2007, 03:28 pm
