Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    trefan123's Computer Details
    win 10
    asus laptop i7
    Mechanical
    trefan123's Discipline Details
    Piping Designer
    Mechanical
    AutoCAD 2013
    Jul 2017
    Traveller
    13
    Unhappy Add previous objects to group
    Good day,
    What i know is dangerous.
    I have a basic lisp that draws a couple of lines and arc's.
    (command "LINE" IP P4 P5 P6 P16 P15 P14 "C")
    (command "LINE" P1 P8 "")
    (command "LINE" P11 P18 "")
    (Command "arc" P5 P7 P8 "")
    (Command "arc" P8 P9 P18 "")
    (Command "arc" P18 P17 P15 "")
    I would like to group these items for ease of manipulation.
    All help is appreciated.
    Thanks
    Peter
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,447
    Hi,
    something like:
    Code:
    (setq objlist (list (setq entity (entlast))))
    (while (setq entity (entnext entity))
      (setq objlist (cons (vlax-ename->vla-object entity) objlist))
    (vlax-invoke
      (vla-add (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))) "*")
      'appenditems
      objlist
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    Here's another way, which may be easier to understand for a beginner:
    Code:
    (setq ent (entlast))
    (while (setq tmp (entnext ent)) (setq ent tmp))
    (command
        "_.line" "_non" IP   "_non" P4  "_non" P5 "_non" P6 "_non" P16 "_non" P15 "_non" P14 "_c"
        "_.line" "_non" P1   "_non" P8  ""
        "_.line" "_non" P11  "_non" P18 ""
        "_.arc"  "_non" P5   "_non" P7  "_non" P8
        "_.arc"  "_non" P8   "_non" P9  "_non" P18
        "_.arc"  "_non" P18  "_non" P17 "_non" P15
        "_.-group" "_c" "*" ""
    (while (setq ent (entnext ent)) (command ent))
    (command "")
    @Grrr beware of circumstances in which the last entity in the database is complex (e.g. Heavy/3D polyline / attributed block)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,447
    Quote Originally Posted by Lee Mac View Post
    Thanks Lee, I just understood what you did in the first two rows of your suggestion, and then I read your remark.
    Now I think that a subfunction that determines if an entity is parent (returns boolean), would pair nicely with entnext.
  5. #5
    Junior Member
    win 10
    asus laptop i7
    Mechanical
    Piping Designer
    Mechanical
    AutoCAD 2013
    Jul 2017
    Traveller
    13
    Thanks a lot. I seem to grasp what lee added, i did try the entlast previously ..just errors...
    One question why put the non in front of the points?
  6. #6
    Junior Member
    win 10
    asus laptop i7
    Mechanical
    Piping Designer
    Mechanical
    AutoCAD 2013
    Jul 2017
    Traveller
    13
    Here is the complete lisp, must have had the old one loaded as it worked but the addition fails
    (defun C:boltside (/ IP P1 P2 P3 SIZE)
    ;================make and choose color=========================
    (command "LAYER" "M" "Steel" "c" "green" "" "")
    (command "color" "white" "")
    (setvar 'osmode 53)
    ;=================insertion point========================
    (setvar "CMDECHO" 0)
    (setvar "BLIPMODE" 0)
    (setq IP (getpoint "\nInsertion Point: "))
    (setvar "OSMODE" 0)
    (setq SIZE (getreal "\nEnter the Nominal Bolt Size--Metric-: ")
    ;====================get all points===================
    (setq P1 (polar IP (DTR 180.0) (* 0.4330 SIZE))
    P2 (polar IP (DTR 180.0) (* 0.6495 SIZE))
    P3 (polar IP (DTR 180.0) (* 0.7655 SIZE))
    P4 (polar IP (DTR 180.0) (* 0.8660 SIZE))
    P9 (polar IP (DTR 90.0) (* 0.8000 SIZE))
    P8 (polar P1 (DTR 90.0) (* 0.7420 SIZE))
    P7 (polar P2 (DTR 90.0) (* 0.8000 SIZE))
    P6 (polar P3 (DTR 90.0) (* 0.8000 SIZE))
    P5 (polar P4 (DTR 90.0) (* 0.7420 SIZE))
    P11 (polar IP (DTR 0.0) (* 0.4330 SIZE))
    P12 (polar IP (DTR 0.0) (* 0.6495 SIZE))
    P13 (polar IP (DTR 0.0) (* 0.7655 SIZE))
    P14 (polar IP (DTR 0.0) (* 0.8660 SIZE))
    P18 (polar P11 (DTR 90.0) (* 0.7420 SIZE))
    P17 (polar P12 (DTR 90.0) (* 0.8000 SIZE))
    P16 (polar P13 (DTR 90.0) (* 0.8000 SIZE))
    P15 (polar P14 (DTR 90.0) (* 0.7420 SIZE))
    ;==================draw nut=======================
    (command
    (command "")
    ;================rotate to desired position=========================
    (prompt "\nRotation Angle: ")
    (command "ROTATE" "LAST" "" IP pause)
    ;================end=========================
    (setvar 'osmode 53)
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,506
    Just a suggestion
    Code:
    (setq a90 (/ pi 2.0)) ; this is 90 degrees
    pi is 180 degrees use as is
    (setq a180 pi)
    (setq a270 (* pi 1.5)) this is 270 degrees
    P3 (polar IP pi (* 0.7655 SIZE))
    P18 (polar P11 a90 (* 0.7420 SIZE))
  8. #8
    Junior Member
    win 10
    asus laptop i7
    Mechanical
    Piping Designer
    Mechanical
    AutoCAD 2013
    Jul 2017
    Traveller
    13
    Embarrassed sorry forgot
    this was not copied
    (defun DTR (a) ;degrees to radians function
    (* PI (/ a 180.0))
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    Quote Originally Posted by trefan123 View Post
    This command modifier is short for "none" and instructs AutoCAD to ignore all active Object Snap modes for the next point input.
  10. #10
    Junior Member
    win 10
    asus laptop i7
    Mechanical
    Piping Designer
    Mechanical
    AutoCAD 2013
    Jul 2017
    Traveller
    13
    learn something every day..
    thanks again
  1. select previous group via lisp problem...
    By danglar in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Mar 2017, 09:07 pm
  2. Replies: 9
    Last Post: 12th Jan 2016, 01:48 pm
  3. Create selection set for previous objects
    By broncos15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2015, 03:57 pm
  4. Stretch a group of objects???!!
    By bbudding in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Nov 2009, 12:29 pm
  5. Viewing how Previous Objects were Created.
    By Jon B in forum AutoCAD General
    Last Post: 14th May 2008, 05:41 pm
