Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    MrCocopuffz's Computer Details
    Windows 10
    DELL Precision 7720
    Construction
    MrCocopuffz's Discipline Details
    BIM Engineer
    Construction
    Civil 3D 2017
    Mar 2018
    8
    Default Join lines on same layer
    Hello everyone. I'm trying to put together a lisp to be able to select a line, which will cause all the lines on that layer to be selected, then using the join command will make any lines connected at the endpoints to become a poly lines. I'm using some code from other lisps and trying to make this work. If I enter each line in on the command line it seems to work but when I use the new command "JLL" nothing really happens. It goes through the process of selecting everything but does not join.
    Code:
    (defun C:JLL ()
    	(setq targetEnt (car (entsel "\nSelect object on layer to select: ")))
    	(setq targetLayer (assoc 8 (entget targetEnt)))
    	(sssetfirst nil (ssget "_X" (list targetLayer)))
    	(command "join" "")
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,541
    In AutoCAD, try running it with QAFLAGS = 1
    Interestingly, it works fine in BricsCAD with QAFLAGS = 0 (the default)
    R.K. McSwain
    CAD Panacea | twitter
    Forum Newbie
    Windows 10
    DELL Precision 7720
    Construction
    BIM Engineer
    Construction
    Civil 3D 2017
    Mar 2018
    8
    It works!!! Thank you so much.
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,541
    I would suggest setting that sysvar in the routine, and returning it to a value of 0 when you're done.
    QAFLAGS at a non-zero value can cause other oddities
    R.K. McSwain
  5. #5
    Forum Newbie
    Windows 10
    DELL Precision 7720
    Construction
    BIM Engineer
    Construction
    Civil 3D 2017
    Mar 2018
    8
    Good to know, thanks for the help.
  6. #6
    Forum Newbie
    Windows 10
    DELL Precision 7720
    Construction
    BIM Engineer
    Construction
    Civil 3D 2017
    Mar 2018
    8
    Would I place (setvar "qaflags" 1) right above the (command "join" "") or under (defun C:JLL ()? Or does it matter?
  7. #7
    Forum Newbie
    Windows 10
    DELL Precision 7720
    Construction
    BIM Engineer
    Construction
    Civil 3D 2017
    Mar 2018
    8
    So I'm watching the text window as it executes and it looks like this:
    Command: jll
    Select object on layer to select: join 1340 found
    5 objects converted to 1 polyline, 1333 objects discarded from the operation
    Command: JLL
    Unknown command "JLL". Press F1 for help.
    Why is it giving me an additionall "JLL" and "Unknown command" at the end?
  8. #8
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    808
    This works using initcommandversion without qaflags:
    Code:
    (defun C:JLL ()
    	(initcommandversion 2)
    	(command-s "join" "")
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  9. #9
    Forum Newbie
    Windows 10
    DELL Precision 7720
    Construction
    BIM Engineer
    Construction
    Civil 3D 2017
    Mar 2018
    8
    Quote Originally Posted by tombu View Post
    Code:
    (defun C:JLL ()
    For some reason, this version doesn't work for me. It asks for the selection but then nothing after.
  10. #10
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    808
    Odd, for me the Command or Text window displays:
    Command: JLL
    Select object on layer to select: join 3 found
    3 objects converted to 1 polyline
    Command:
    after selecting one line it joined it with 2 other lines that shared endpoints.
    What did your Command or Text window display after you selected a line?
  1. How can I Join lines
    By akis123321 in forum AutoCAD General
    Last Post: 27th Feb 2015, 01:58 pm
  2. how to join these 5 lines/arcs?
    By Marvin7 in forum AutoCAD General
    Last Post: 22nd Jul 2013, 08:27 pm
  3. Using Polyedit to join lines
    By manchest in forum AutoCAD General
    Last Post: 11th Oct 2010, 07:53 am
  4. How to join lines on different UCS planes
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Jul 2010, 07:35 pm
  5. join lines
    By azman modular in forum AutoCAD General
    Last Post: 26th Mar 2009, 03:36 pm
