Results 1 to 6 of 6
    Senior Member
    Architectural
    svorgodne's Discipline Details
    Architect. Lisp developer
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    150
    Default define block with autolisp
    Hello everyone,
    Is it possible to get with autolisp while running a block command, to get all possibilities that the normal block command has?
    When running the block command thru autlisp it only gives me two or three possibilities and not the one I need, which is the "convert to block", meaning make a block from selected objects and convert them immediately to a block.
    Thanks in advance
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,177
    Hi,
    Just erase and insert the same block once again in the same location.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    These examples may help you.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    Architectural
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    150
    Quote Originally Posted by Tharwat View Post
    Hi,
    That's precisely, exactly what I want to avoid, because then the handles are changing and the block I try to make is only temporary, so if there are some attributes linked to some entities, like areas or so, then the link is lost because the polylines are new, so thanks a lot but that does not solve my problem.
  5. #5
    Super Member
    not applicable
    Jun 2016
    669
    @svorgodne:
    Have you ever verified this behavior? To my knowledge 'convert to block' creates a block definition with new entities, this block then gets inserted and the original entities are erased. Exploding the insert will again create new entities.
    Maybe you should look at creating a group instead?
    BricsCAD 18
  6. #6
    Senior Member
    Architectural
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    150
    Quote Originally Posted by Roy_043 View Post
    @svorgodne:
    Absolutely right Roy_043, didn't know that was happening. In any case, other parameters are missing when defining a block via autolisp. Hyperlink for example
    Thanks a lot
  1. Block Autolisp
    By nicolas in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jun 2012, 09:29 am
  2. How to get block name By Autolisp?
    By fathihvac in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Aug 2011, 05:15 am
  3. define more than one stretchable area in the same block
    By samifox in forum AutoCAD General
    Last Post: 4th Jul 2011, 02:22 pm
  4. How to define a function in AutoLISP with arbitrary arguments
    By Ahankhah in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Apr 2011, 06:54 pm
  5. Define Block Attributes with field name
    By gnotnoel in forum AutoCAD General
    Last Post: 20th Jun 2006, 06:57 pm
