Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    Default text string issue
    Autocad 2006
    I am using a font style that allows me to use a shortcut for fraction inputs.
    Example: to input 2'-5 1/4", I type 2'-4%%204". This gives me a condensed stacked fraction in single text input only.
    Here is my problem:
    When I input this in and before I hit enter everything looks ok. The fraction is shown like I am used to seeing. But when I hit enter the fraction disappears. Now if I double-click on the text and it highlights it, the fraction appears again, but when I hit enter, it is gone. I hightlighted the text and hit properties and instead of showing 2'-5%%204" in the text string box, it shows 2'-5\U+00D4. If I edit the text string box to 2'-5%%204", then the text is changed correctly.
    Why doesn't Autocad recognize it when I just edit/input text without having to go through properties?
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    come on guys...any ideas? I made sure the font was not corrupt and it is being used on other computers with 2006 and I have used it now for 2 years. I think it has gotta be some text imput command that I need to turn on or off but I have tried and failed.
    What command(s) affect the text string imput? It is as if %% executes another set of shortcuts or something.
    Full Member jules_s's Avatar
    Architecture 2013
    Nov 2006
    england
    79
    Quote Originally Posted by jpcedotal View Post
    Hi,
    I'm new here, but I've never been adversed to making a fool of myself when amongst people with greatly superior knowledge
    Have you checked the drawing parameters are set up correctly in the 'units' command?
    Just a thought, i'm not sure it affects text dialogue input...but thats all I can come up with.
    Over to those more in the know
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    nah, tried that. I did notice in the command line when I hit enter an error message comes up stating "undefined shape 204" I take it the 204 is the shortcut I used to get 1/4". I think the %% is what is tricking Autocad into thinking there is something else going on....
  5. #5
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,059
    are you sure you have the correct font file specified? (Check in STYLE). I recently couldn't read the Russian text in a drawing although it was fine on all the other machines. It seems AutoDesk have changed the Simplex font to an extended set and I only had the former file available. Why it didn't update is another matter entirely.
    % is the AutoCAD shortcut for "modify the following text". as in %p = plus|minus symbol, %d = degree symbol, %c = diameter symbol and %% = % symbol. I think it looks at the characters above position 127 for the symbol IYSWIM. If you are using a TTF font you should be able to use Windows charecter map to view.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  6. #6
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    I also have Autocad 98 LT and Autocad 2000 LT installed and the shortcuts work fine on those two versions. And like I stated before, when I just dedit text the fraction shows up until I hit enter then it disappears and moves the inch mark over. I can then click on it and go to properties and input %%212 and it works. Is there some sort of command that determines how dedit works?
  7. #7
    Full Member acemasi's Avatar
    Civil 3D 2008
    Oct 2006
    Fiji
    57
    Default Stacking
    Type 2'-5" 1/4 on Mtext window, highlight 1/4 only, right click and go to autostack. Try if it works out.
  8. #8
    Civil 3D 2008
    Oct 2006
    Fiji
    57
    sorry, type 2'-5 1/4", higlight 1/4 not the inch symbol, right click, go to stack and a window will appear, where you'll have options to check or uncheck. try & see what happens
  9. #9
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    nah that ain't it. My shortcut keys don't work in multi-text, only in single text.
  1. string text
    By brassworks in forum AutoCAD Drawing Management & Output
    Last Post: 6th Oct 2006, 03:04 pm
  2. need lisp routine for global text string change
    By TFerg in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jul 2006, 03:46 pm
  3. Adding a String to the Text Command
    By muppetfan88 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Apr 2006, 03:49 am
  4. Insert Text String
    By Bass'nBoots in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2005, 06:32 pm
  5. plot preview and text issue
    By dlthom in forum AutoCAD Beginners' Area
    Last Post: 20th Jul 2005, 03:30 pm
