AutoCad 2007 black screen on Win 10
Levco101
Have been running 2007 on Win 7 for years. Installed 2007 on a new I7 HP
with Win 10 64 pro. It installed and registered in the Win 7 compatiable mode.
2007 runs with administrator and loads a drawing and runs behind a black screen. The command line cursor works, the menus work, but no visual tool tip or cross hairs, the cordinates increase/decrease, etc.
Besides Longbow, is there a fix?
Thanks,
Stan
I7-4770 3.4ghz, 8 gig, 1TB
Turn off hardware acceleration and see if that helps.
Longbow Software's website also offers many other free tips to try that may help without having to buy their fix (kind of nice of them to do that).
Dean: This I-7 4770 does not let me change the Hardware Acc. None of Longbow's tips help.
Thanks,
Stan
correction: I7-4770 3.4ghz, 16 gig, 1TB
Thanks,
Stan
Welcome to CADTutor Levco. :)
Just a guess, I have never used Longbow, nor Windows 10, am still using 8.1, but Longbow does have a good track record for dealing with just these sorts of issues through the years.
I think that having exhausted all of their non-pay suggestions (which is very nice of them:)), that it might be a good time to reach out to them through their contact link, and ask if they are aware of any paying users, for whom Longbow has solved a similar issue, specifically with Windows 10. :|
Were you able to open OPTIONS, and look on the SYSTEM tab, for hardware acceleration?
The Hardware Acceleration setting you should be looking for is within Autocad, as described on the SYSTEM tab.
At least that is where it is nowadays. I am not sure about 2007, I started on 2009.
Hardware Acceleration is available in AutoCAD, try Options>Systems>3d Performance, it has nothing to do with any particular computer.
What graphics card do you have? It may be as simple as finding the best driver.
The easy fix is to use a program designed for Windows 10 or install Windows 7.
  • 1 month later...
I tried everything found here and on other web searches. Ended up
installing the Longbow Converter. My AutoCad 2007 is working perfectly
so far-10 days or so.
Thank you all for your HELP!!!
Stan
  • 2 months later...
  • 5 years later...
