ThrashMetal Posted May 23, 2018 Share Posted May 23, 2018 hey all, first time i encountered my dimension showing an inaccurate distance, for example the scale was set to 1:20, the dimension should only be about .60 of a meter but it shows 3 meters, and it changes every time i change scale on the layout page. also, all multiviews in that page has accurate dimensions. help..thanks a bunch Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 23, 2018 Share Posted May 23, 2018 Is the object being dimensioned 2D or 3D? Quote Link to comment Share on other sites More sharing options...
ThrashMetal Posted May 23, 2018 Author Share Posted May 23, 2018 its in 2D.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 23, 2018 Share Posted May 23, 2018 Did you check that the end points of the object have a "Z" of 0? Quote Link to comment Share on other sites More sharing options...
pendean Posted May 23, 2018 Share Posted May 23, 2018 Dimension? Is that in paperspace or modelspace (through the viewport if there is one)? What does DIST command show in modelspace? If you draw a line between the two points, what does LIST command show in modespace? Quote Link to comment Share on other sites More sharing options...
ThrashMetal Posted May 25, 2018 Author Share Posted May 25, 2018 First off, i would like to say thank you for the reply "Did you check that the end points of the object have a "Z" of 0?" - That I did not do sir since i assumed Z would only come out on model work space so that thought did not enter my mind, and no other items on the model space was on 3d. I actually solved the problem but i don't know if its really the proper solution to it. what I did was take the dimension points from a point on the drawing that would not register other dimensions, (example: thickness of wall), when the dimension came out as .15 of a meter, i continued with the dimension of the others that needed measuring and did matchdrop command using the thickness of the wall as reference and it came out good. i know its a simple solution but I know the problem lies with my settings. Quote Link to comment Share on other sites More sharing options...
