kevinfaj Posted May 24, 2018 Share Posted May 24, 2018 I made below lisp code to have field code copied to text,dim etc. but not work on ATT thing anyone could help me with this how to make it happen that copy field code to ATT? :) (defun c:ffd () (progn (setvar "cmdecho" 0) (setvar "blipmode" 0) (vl-load-com) (progn (setq ent (entsel "select text to be copied:")) (setq egg (cdr (assoc 0 (entget (car ent))))) (setq entx (vlax-ename->vla-object (car ent))) (cond ((= egg "INSERT") (setq entp (entget (car (nentselp (cadr ent))))) (setq entr (cdr (assoc -1 entp))) (setq objid (vla-get-objectid (vlax-ename->vla-object entr))) (setq field (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ">%).TextString>%")) ; %<\AcObjProp Object(%<\_ObjId 8796059764128>%).TextString>% ; %<\AcObjProp Object(%<\_ObjId 8796083319744>%).TextString>% ) ((= egg "DIMENSION") (setq objid (vla-get-objectid entx)) (setq field (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ">%).Measurement \\f \"%lu2\">%")) ) ) ;%<\AcObjProp Object(%<\_ObjId 8796059773904>%).Measurement \f "%lu2">% (setq ent1 (entsel "copy to:")) (setq egg1 (cdr (assoc 0 (entget (car ent1))))) (setq entx1 (vlax-ename->vla-object (car ent1))) (cond ((= egg1 "INSERT") (setq entp (entget (car (nentselp (cadr ent1))))) (setq entr (cdr (assoc -1 entp))) (vla-put-TextString (vlax-ename->vla-object entr) field) ) ((OR (= egg1 "TEXT") (= egg1 "MTEXT")) (vla-put-textstring entx1 field) ) ((= egg1 "DIMENSION") (vla-put-TextOverride entx1 field) ) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 24, 2018 Share Posted May 24, 2018 When populating an attribute with a field expression, you will need to use the UPDATEFIELD command or issue REGEN for the field expression to be correctly displayed - you may wish to refer to Copy Field program for a similar example, or my Length Field program for a more extensive example which operates with a wider range of objects. Quote Link to comment Share on other sites More sharing options...
kevinfaj Posted May 25, 2018 Author Share Posted May 25, 2018 thanks, just put in updatefield ,and all solved, thanks for help:D Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 25, 2018 Share Posted May 25, 2018 You're welcome! Quote Link to comment Share on other sites More sharing options...
