Text and dimension in block after scaling
zionshea
Hello,
I am using a block including text and dimensions. It is used in a layout.
After scaling the block dimension text is not changes but the size of the dimension text IS scaled. The same with any text within the block.
Is there a way to ask Autocad to keep the dimension and text size as the original so this will not be changed after block scaling?
(This is something like annotative dimension and text but then I should use this with the model and use also layout with scaling...)
Thanks
zionshea
