C# setting HPNAME not working
pwned555
I'm trying to update a few system variable in C# based on what button a user selects. I'm having some issues with the HPNAME system variable.
I set the variables like this:
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("HPNAME", HPNAME);
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("HPSCALE", HPSCALE);
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("HPANG", HPANG);
I'm trying to set HPNAME to GRASS, when I step through the code it is correctly trying to set HPNAME to GRASS however nothing happens and the system variable is never changed. When I manually change HPNAME to GRASS in the command line it works fine.
The other two system variables above are correctly changing values.
Are there any issues with changing HPNAME? I have tried hard coding GRASS as well to test but no success.
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("HPNAME", "GRASS");
Thanks,
  • 2 months later...
Stupid thing, needed to lock the document to be able to update some of the system variables. Everything is working now, thanks.
