Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
  1. #21
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    I have tested with the same file which i already posted on Post#7
  2. #22
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,227
    That txt file has one line of data and the handle there does not match any of the attributed blocks in the drawing so no wonder the program did nothing since it did not match any of the handle strings of the existed blocks.
  3. #23
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    Could you please check the sample file?
    Att.txt
    Sample.dwg
  4. #24
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,227
    You have an extra apostrophe in every handle string in the txt file and that is the issue.
  5. #25
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    But the Text, i have get using ATTOUT Command. I't is came like that only.
    Usually it's coming one apostrophe right?
    Please give me the corrected text file if you have.
  6. #26
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,227
    If that is the case then just replace the following line of codes with the related codes from the program and try it gain.
    Code:
    (setq soc (assoc (strcat "'" (cdr (assoc 5 (entget ent)))) lst))
  7. #27
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    Awsome!!!
    It's working perfectly, Thank you so much for your valuable support.
    Thank you so much.
  8. #28
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,227
    You are welcome anytime.
  9. #29
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    My $0.05 why would you not move your directory up the tree ? like "B:\Lisp" you are making hard work for your self remembering that path. Just add it to the support paths as well using CONFIG.
  1. Lee Mac's Update Title Block
    By Craisbeck in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2013, 05:04 pm
  2. Trying to Automatically update/redefine block in Thousands of drawings
    By john_waggs in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 13th Feb 2013, 02:19 pm
  3. Automatically Update Title block lisp HELP!
    By Millsy29 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jul 2010, 05:29 pm
  4. Update the attribute title block
    By andy_gs in forum AutoCAD Beginners' Area
    Last Post: 4th May 2010, 04:22 am
  5. Title Block Update
    By eddablin in forum AutoCAD Drawing Management & Output
    Last Post: 18th Apr 2009, 01:35 pm
