Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: simple area
    Junior Member
    AutoCAD 2010
    May 2018
    Quebec, Canada
    11
    Question simple area
    i'm looking for a simple area routine base on the dimension not the line.
    i want to be able to click on 2 cotation that i got from the dimlinear command and have the area "print" in a text format where i want to.
    I know a routine with a lot of visual lisp routine in it, but i'm looking a version with a standard/ basic lisp.
    thank you.
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,224
    Hi,
    Is it something like select the 1st dimlinear then the 2nd one then specify a point to place the area as a text object which supposed to be produced from multiplying of dim text1 and dim text2 ?
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,224
    This?
    Code:
    (defun c:Test ( / dm1 dm2 en1 en2 obj get hgt ins )
      (and
        (setq dm1 (car (entsel "\nSelect 1st dimlineaer :")))
        (or (member '(100 . "AcDbAlignedDimension") (setq en1 (entget dm1)))
            (alert "Invalid object.<!>")
        (setq dm2 (car (entsel "\nSelect 2nd dimlineaer :")))
        (or (member '(100 . "AcDbAlignedDimension") (setq en2 (entget dm2)))
        (setq obj (tblobjname "BLOCK" (cdr (assoc 2 en1))))
        (while (and (not hgt) (setq obj (entnext obj)))
          (and (= (cdr (assoc 0 (setq get (entget obj)))) "MTEXT")
               (setq hgt (assoc 40 get))
        (setq ins (getpoint "\nSpecify location of text area :"))
        (entmake (list '(0 . "TEXT") (cons 10 (trans ins 0 1)) (cons 11 (trans ins 0 1)) hgt
                       (cons 1 (rtos (* (cdr (assoc 42 en1)) (cdr (assoc 42 en2))) 2))
    Junior Member
    AutoCAD 2010
    May 2018
    Quebec, Canada
    11
    exactly. i'll try your code.
  5. #5
    Junior Member
    AutoCAD 2010
    May 2018
    Quebec, Canada
    11
    work perfectly thank...
    If i can ask you an other issue.
    if i have a few area measurement and i want to have the total, what would be the routine/formula?
    thank
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,224
    You're welcome.
    Quote Originally Posted by bogeymen77 View Post
    Do you mean that you would like to sum texts with numerical values to new text as total areas?
  7. #7
    Junior Member
    AutoCAD 2010
    May 2018
    Quebec, Canada
    11
    yes. for exemple i got 4 piece of counter top ,i got the area for each one. After i would like to have the sum of all 4 pieces.
    thank you
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,224
    What do you mean by counter top?
    Can you upload a sample drawing showing the outcome of the process that you looking forward?
  9. #9
    Junior Member
    AutoCAD 2010
    May 2018
    Quebec, Canada
    11
    Default counter top
    i'm drawing counter top. here'S an example
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    I am sure Tharwat will continue to answer there are a few different ways to do this.
    1 Pick text and add up.
    2 Select text on one layer, your dwg its on layer 0 needs to be something different, like table-area.
    3 Make a block and have an attribute then just total all attributes.
    4 like 3 but make an Autocad table of the areas with common table top styles.
    It would be good at this point to suggest which method you want so its not a case of multiple changes.
    Could not resist suggestion 1, this is real basic no error checking.
    Code:
    (defun c:test ( / tot ent obj)
    (setq tot 0.0)
    (while (setq ent (entsel "\nPick text Enter to stop"))
    (setq obj (vlax-ename->vla-object (car ent)))
    (setq tot (+ (atof (vla-get-textstring obj)) tot))
    (alert (strcat "The total area is = " (rtos tot 2 3 )))
  1. Simple question, so apologies if it's too simple!
    By dueingx4 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jan 2015, 11:58 am
  2. simple simple... connecting to 2006 via interop
    By btraemoore in forum .NET, ObjectARX & VBA
    Last Post: 29th Apr 2013, 03:39 pm
  3. simple area macro
    By cproudfoot in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2008, 12:22 pm
  4. Quick & simple work area setup tips needed
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 17th Mar 2006, 05:46 am
Tags for this Thread
