Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: simple area
  1. #11
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,225
    Code:
    (defun c:sum (/ int tot sel ent int val ins)
      ;; Tharwat -  Date: 09.Jun.2018	;;
      (princ "\nSelect text areas to sum :")
      (and (setq int -1
                 tot 0.0
                 sel (ssget "_:L" '((0 . "TEXT")))
             (while (setq ent (ssname sel (setq int (1+ int))))
               (and (numberp (setq val (read (cdr (assoc 1 (entget ent))))))
                    (setq tot (+ tot val))
             (< 0.0 tot)
           (setq ins (getpoint "\n Specify text location :"))
           (entmake (list '(0 . "TEXT")
                          (cons 10 (trans ins 0 1))
                          (cons 11 (trans ins 0 1))
                          (cons 40 (getvar 'TEXTSIZE))
                          (cons 1 (rtos tot 2))
    Junior Member
    AutoCAD 2010
    May 2018
    Quebec, Canada
    11
    works Perfectly !!! WOW thanks you all !!!
  3. #13
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,225
    Quote Originally Posted by bogeymen77 View Post
    You're welcome.
  4. #14
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,585
    Nicely done Tharwat. Maybe 1 little suggestion.
    Code:
    (cons 1 (strcat "Area = " (rtos tot 2)))
  5. #15
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,225
    Quote Originally Posted by BIGAL View Post
    Thank you BIGAL.
    Code:
    Yes indeed it is a very good suggestion and make sense.
  1. Simple question, so apologies if it's too simple!
    By dueingx4 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jan 2015, 11:58 am
  2. simple simple... connecting to 2006 via interop
    By btraemoore in forum .NET, ObjectARX & VBA
    Last Post: 29th Apr 2013, 03:39 pm
  3. simple area macro
    By cproudfoot in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2008, 12:22 pm
  4. Quick & simple work area setup tips needed
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 17th Mar 2006, 05:46 am
Tags for this Thread
