Lithium Posted June 10, 2018 Share Posted June 10, 2018 AutoCAD LT 2009 "Viewport is view-locked. Switching to Paper space. Switching back to Model space." What does this mean? Is there something I should change? If I hit F2 I see this repeated about five or six times. It does not switch back to Model space. It stays in Paper Space. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 10, 2018 Share Posted June 10, 2018 Select the viewport, then in PROPERTIES you can unlock it, if you are sure that is what you want to do. Then you can reset the view in your viewport, as well as the scale, visual style, etc. Once you have it set up how you want it, make sure you lock it again, if you want to maintain the view, scale and settings you have set. Quote Link to comment Share on other sites More sharing options...
