Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    AutoCAD 2016
    Oct 2017
    21
    Default Distance between lines
    Need a lisp that would calculate distance between lines in a map and place it at the center of each lines.
    I need to select all the lines at once instead of selecting each line one by one.
    Regards,
    lucky9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,592
    Now where is the crystal ball so I can see what you want.
    Please post a dwg or image.
    Junior Member
    AutoCAD 2016
    Oct 2017
    21
    Sample Drawing is attached for your reference..
    it would be nice if the lengths are placed similar as it is shown in the drawing.
    thanks
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    718
    hi you should ask lisp question in
    AutoLISP forum
    Code:
    (defun c:test (/ en d p p2 tx1 tx2)
      (setvar 'dimasz 15)
      (while (setq en (car (entsel "\nPick polyline.. ")))
        (and (wcmatch (cdr(assoc 0 (entget en))) "*LINE")
    	 (setq d   (vlax-curve-getdistatpoint en (vlax-curve-getendpoint en))
    	       p   (vlax-curve-getpointatdist en (* d 0.5))
    	       tx1 "100MM %%C"
    	       tx2 (strcat "L=" (rtos d 2 0) "M")
    	       p2  (if (and pointer:marker msg:pointer) (msg:pointer (list (trans p 0 1)) 1 (strcat tx1 "\\P" tx2))
    		     (getpoint p "\nSpecific next point.. "))
    	 (vl-cmdf "_leader" "_non" (trans p 0 1) "_non" p2 "" tx1 tx2 "")
    visual utility
    msg:pointer
    p/s: @BIGAL i noticed you were offline while the OP was online my quick reply didn't mean to hijack.
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  5. #5
    Junior Member
    AutoCAD 2016
    Oct 2017
    21
    Hi there , I tried your solution when selecting the polyline it does nothing.
    here is a screen capture.
    Btw, I post the question in wrong section by mistake if any mod would move this post to the right section would be appreciated.
    Thanks
  6. #6
    AutoCAD 2007
    Apr 2013
    Happy Garden
    718
    Quote Originally Posted by lucky9 View Post
    Thanks
    did you download the visual utility link provided ?
    missing routine?
    pointer:marker
    msg:pointer
    i edited previous post, try it still can run without these visual utilities.
    please retry
  7. #7
    Junior Member
    AutoCAD 2016
    Oct 2017
    21
    Quote Originally Posted by hanhphuc View Post
    missing routine?
    pointer:marker
    msg:pointer
    please retry
    I didn't download it ,
    are you referring to msg:pointer code?
    Awesome !
    Thanks
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,592
    Hanhphuc I would use the simple check for a library routine. I like the look of the pointer code will have a closer look.
    Code:
    (if (not msg:pointer)(Load "msg-pointer")) ; save lisp as say msg-pointer
  9. #9
    AutoCAD 2007
    Apr 2013
    Happy Garden
    718
    Quote Originally Posted by BIGAL View Post
    Code:
    Thanks BIGAL it makes sense, if OP keeps this sub different file
  10. #10
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the most relevant Forum.
  1. finding distance between offset lines
    By fisher22 in forum AutoCAD Beginners' Area
    Last Post: 6th Jul 2011, 06:40 pm
  2. distance between points in lines ?
    By yajis_narif in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2011, 09:20 pm
  3. [VBA/Autocad]The shortest distance between two lines
    By lubracali in forum .NET, ObjectARX & VBA
    Last Post: 8th Feb 2011, 03:29 am
  4. lines (bearing/distance)
    By cordgrass in forum AutoCAD Beginners' Area
    Last Post: 16th Jul 2009, 04:34 pm
  5. Distance between two lines
    By undoman in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jun 2006, 06:58 am
