Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Junior Member
    AutoCAD 2016
    Oct 2017
    18
    Quote Originally Posted by hanhphuc View Post
    Thanks BIGAL it makes sense, if OP keeps this sub different file
    Guys could you please elaborate more... I'm pretty basic in lisp.
    What is visual utility and how to install it or make it to work?
    Thank you !
  2. #12
    Junior Member
    AutoCAD 2016
    Oct 2017
    18
    Although, your solution worked pretty awesome! but what is this visual utility thingy?
  3. #13
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    711
    Quote Originally Posted by lucky9 View Post
    it was just my naming for those transient routines.
    ACAD also has osmode, gridmode , 3dorbit & vslide etc..
    example getpoint 'rubber band'
    Code:
    (setq p (getpoint ))
    (setq p2 (getpoint p)) ; <-- with rubberband
    Code:
    (setq p2 (getpoint )) ; <-- without rubberband you can't see startpoint
    you can call any naming as you like.
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  4. #14
    Junior Member
    AutoCAD 2016
    Oct 2017
    18
    Thank you! hanhphuc
  1. finding distance between offset lines
    By fisher22 in forum AutoCAD Beginners' Area
    Last Post: 6th Jul 2011, 06:40 pm
  2. distance between points in lines ?
    By yajis_narif in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2011, 09:20 pm
  3. [VBA/Autocad]The shortest distance between two lines
    By lubracali in forum .NET, ObjectARX & VBA
    Last Post: 8th Feb 2011, 03:29 am
  4. lines (bearing/distance)
    By cordgrass in forum AutoCAD Beginners' Area
    Last Post: 16th Jul 2009, 04:34 pm
  5. Distance between two lines
    By undoman in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jun 2006, 06:58 am
