Results 1 to 4 of 4
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    AutoCAD Set two scale bar
    Hi Everyone
    I have to draw a elevation view as per dimensions, but i need to draw the view with two scale. For horizontal 1:500 and vertical 1:200.
    Really I don't have an idea how to do this.
    Please anyone help me. And also please explain briefly about scale..
    If i want to draw 10m line on 1:200 scale...can i draw for 10m or need to some calculations for that?
    Thanks in advance
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Create a grid based on the two scales similar to what one might do if drawing a sewer profile.
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    But. I have change the size of the scale bar using scale command..
    Senior Member
    AutoCAD 2016
    Jan 2012
    170
    Draw the view as you normally do, make a block of it and then insert the block. When interting the block, you can specify the scale for X and Y separately.
  1. Replies: 0
    Last Post: 6th Feb 2018, 09:10 pm
  2. Insertion scale of xrefs ends up as .0625 no matter what scale I set
    By LFreels in forum AutoCAD Drawing Management & Output
    Last Post: 11th Dec 2014, 05:18 pm
  3. Layout tab's viewport scale box won't show standard scale menu.
    By macsee in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2014, 01:36 pm
  4. Model Scale vs. Viewport Scale vs. Plot Scale?
    By Sbeth85 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Jan 2014, 04:32 pm
  5. Lint Type Scale changes when i change annotation scale!!
    By JBullseye74 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Jun 2009, 02:30 pm
