Results 1 to 7 of 7
    Junior Member
    RobertR's Computer Details
    Windows 7
    Dell Optiplex 3020
    Intel Core i5-4590 @ 3.30GHz
    8 GB
    Intel HD Graphics 4600
    Samsung SSD PM851 128GB ATA
    (2) 22" Viewsonics
    Architectural
    RobertR's Discipline Details
    Draftsman II
    Architectural
    steel panel systems for roofs, walls & soffits
    AutoCAD 2019
    Oct 2011
    Bossier City, LA, USA
    11
    Default Locked viewport acts unlocked
    Dell Optiplex 3020
    AutoCAD 2019 updated (P.61.0.0 AutoCAD 2019.0.1)
    Logitech M500 corded mouse
    I am in paperspace, zooming in and out, copying item tag blocks over a locked viewport.
    The view in the viewport will suddenly act as if I am IN an unlocked viewport and zooms out/pans.
    Hitting undo a few times gets it back to the right view. It only happens occasionally and only since I upgraded to 2019. As 2018 got buggy and kept crashing, I can't go back to it.
    Saved/exited/reopened the drawing...still does it.
    Purge...still does it.
    Audit...still does it.
    Dxfout & open dxf...still does it.
    I notice that whenever it happens, the viewport goes from
    Annotation scale: 3/32 = 1'-0", Standard scale: 3/32 = 1'-0", Custom scale: 0"
    to
    Annotation scale: 3/32 = 1'-0", Standard scale: Custom, Custom scale: 0"
    Attached is the drawing saves as 2013
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,572
    Could it be that you're executing the VPMAX mode?
    R.K. McSwain
    CAD Panacea | twitter
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by rkmcswain View Post
    +1 That sounds like a good hypothesis rk.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,771
    IMHO, you have accidentally activated the viewport. There is nothing wrong with your dwg file. Double clicking anywhere inside the viewport frame, on purpose or not, will move you to modelspace through the viewport whether it is locked or not. If the viewport is in the maximized state, you can zoom, Pan, and edit all over modelspace at will even if the viewport is locked. If the viewport is not maximized, and is locked, you will not be able to zoom, or pan, but you will be able to edit objects you can select in that view.
    If you are already zoomed far enough when the viewport is activated, VPMAX occurs automatically because AutoCad thinks that is what you want. I do think the automatic nature of this is a 2019 thing, but it is not a bug. My 2019 does it to, and I often use it. Since my average layout count is in the triple digits, it is a serious PITA to keep going back to full modelspace to edit stuff.
    While the viewport is maximized, you will be able to zoom and pan, and edit modelspace at will, as if the viewport is not locked, and this part has always been the case.
    Undo is not necessary. Simply type PS then hit enter to return to paperspace, or click the modelspace/paperspace toggle button on the taskbar. Once in paperspace again, the viewport automatically returns to the locked scale and paperspace zoom level you were at originally.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Junior Member
    Windows 7
    Dell Optiplex 3020
    8 GB
    (2) 22" Viewsonics
    Architectural
    Draftsman II
    Architectural
    AutoCAD 2019
    Oct 2011
    11
    All good theories and I have done that before. However, in this case I am still in paperspace. Zooming out with the mouse wheel shows the viewport and title block. As I copy the item tags (in paperspace), the locked viewport will pan/zoom without me even entering it. I am wondering if it's simply a graphics issue. My work didn't buy a graphics card and I am using the onboard "Intel HD Graphics 4600".
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,771
    Quote Originally Posted by RobertR View Post
    Oh, ok since you are definitely in paperspace, it may well be the graphics card delaying the viewport image as the rest of the screen moves around, or vice-versa. I have witnessed similar behavior on my home computer running 2018 LT with only the on board chip. An on board graphics chip simply will not handle the current processing needs of AutoCad. Someone needs to inform your company of the AutoCad system requirements.
  7. #7
    Junior Member
    Windows 7
    Dell Optiplex 3020
    8 GB
    (2) 22" Viewsonics
    Architectural
    Draftsman II
    Architectural
    AutoCAD 2019
    Oct 2011
    11
    I've laid my case before my boss and he agreed. New graphics card for everyone!
  1. Replies: 15
    Last Post: 2nd Feb 2012, 12:07 am
  2. Unlocked Viewport - Zoom Extents
    By dej-b&v in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Dec 2010, 08:30 pm
  3. Locked Viewport
    By SteveB in forum AutoCAD Beginners' Area
    Last Post: 7th Jul 2009, 07:01 pm
  4. Locked or Unlocked?
    By JaketheMan in forum AutoCAD Beginners' Area
    Last Post: 18th Feb 2009, 10:57 pm
  5. Locked Viewport
    By solofusion in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2007, 05:29 pm
Tags for this Thread
