Results 1 to 4 of 4
    Senior Member
    numberOCD's Computer Details
    Windows 7
    HP EliteBook 8770w
    16Gb
    MEP 2014
    Apr 2010
    Chicago/New York USA
    165
    Default Annotative Circle or Dot
    Hey guys,
    I'm looking for any method to have an annotative circle or dot in a dynamic block.
    I'm marking street lights along the highway with a circle and am throwing an attribute text with its name plate on the side in Defpoints.
    Is there a way to make the circular or dot shape annotative to remain 0.100 inches diameter no matter the zoom?
    Thanks
    Senior Member pendean's Avatar
    pendean's Computer Details
    Windows 10 64it Pro
    Lenovo WorkStation
    Architectural
    AutoCAD 2018
    Jun 2011
    Texas
    131
    Not independently from your dynblock's annotative abilities, no: you will need to include sizes to manually adjust (PS use a DONUT object if you want a "dot" that sizes up and down).
    Dean Saadallah
    AutoCAD and LT User
    BLOG|TW|FB|PIN
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Yup, once an object is inside of a block it's just another part of the block. It's the block that is annotative itself.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,566
    Exclamation
    Quote Originally Posted by numberOCD View Post
    If you draw a circle 0.1" in diameter, it will always be that size, no matter the zoom level.
    Perhaps you mean that you want this circle to always be the same size in screen pixels, no matter the zoom level?
    Like this?
    R.K. McSwain
    CAD Panacea | twitter
  1. Lisp to convert Annotative TEXT to Annotative MTEXT
    By Tripledot in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Feb 2016, 06:28 am
  2. Annotative Block With Dynamic Properties - Rotation Issues at Annotative Scales
    By nwinslow in forum AutoCAD Drawing Management & Output
    Last Post: 7th Aug 2015, 07:34 am
  3. Replies: 3
    Last Post: 4th Sep 2014, 05:33 pm
  4. circle center line(Like Plus symbol and after circle 4 sides 5mm extra length)
    By johnpieter in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Dec 2010, 02:23 pm
  5. Insert annotative block as non annotative dwg + trim object scalelist
    By Fnuik in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2010, 09:14 pm
Tags for this Thread
