Results 1 to 3 of 3
    Junior Member
    AutoCAD 2008
    Mar 2008
    15
    Default VBA change layers
    Hello,
    I am trying unsuccessfuly to switch layers from EXCEL.
    This is my code:
    Please advise
    Thanks
    Code:
    Public Sub MISKO()
    Dim ACAD As AcadApplication
    On Error Resume Next
    Set ACAD = GetObject(, "AutoCAD.Application")
    Call ACAD_SELECT_LAYER("BIBI")
    End Sub
    Public Sub ACAD_SELECT_LAYER(A$)
    Dim ACAD As AcadApplication Dim objLayer As AcadLayer
    Dim acadDoc As AcadDocument
    Set ACAD = GetObject(, "AutoCAD.Application") 'Get a running instance of the class AutoCAD.Application
    Set acadDoc = ACAD.ActiveDocument
    Set objLayer = acadDoc.Layers(A$) ‘ < supposed to select this layer passed by A$
    End Sub
    Senior Member
    Civil
    Hippe013's Discipline Details
    Survey Crew Chief / Civil Designer
    Civil
    Land Survey / Civil Engineering
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    The following is from Autodesk Help
    Code:
    Dim newlayer As AcadLayer
    Set newlayer = ThisDrawing.Layers.Add("LAYER1")
    ThisDrawing.ActiveLayer = newlayer
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,577
    katto01 you may want to look into setting variables using vba there are so many "clayer" "osmode" "style" to mention a few Hippe013 has answered layer there is probably a list somewhere vba v's autocad v's LIsp.
  1. I cannot change the LineType in my layers :(
    By salaxi in forum AutoCAD General
    Last Post: 8th Jun 2013, 05:31 pm
  2. Using Layers to change viewports
    By jaredmccullough in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2013, 02:55 am
  3. Change layers to blocks
    By NStocks in forum AutoCAD Drawing Management & Output
    Last Post: 24th Apr 2008, 07:42 pm
  4. change color of layers
    By Tiger in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Nov 2007, 06:26 pm
  5. Using scripts to change layers?
    By Brendan in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jul 2007, 05:49 pm
Tags for this Thread
