+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Super Member hanhphuc's Avatar
    Using
    AutoCAD 2007
    Join Date
    Apr 2013
    Location
    Happy Garden
    Posts
    710
    Default
    Quote Originally Posted by Emmanuel Delay View Post
    Attachment 64046
    I wrote something. It doesn't solve everything, but it can be a help to the file that you posted.
    I'll provide my own simplified dwg.
    hi, Thanks your example, now i figure out a bit electrical job
    using previous sub function foo
    This example will increase the space only, based on OP's title 'Increase the space between multiple lines'
    Code:
    (defun c:test ( / s l i d e ) ; Increase the space between multiple vertical lines
    ;hanhphuc 19.06.2018
    (initget 7)
    (and
    (setq d (getdist "\nSpecify space distance : "))
    (setq s (ssget ":L" '((0 . "LWPOLYLINE") (-4 . "=") (70 . 0) (90 . 4)))
    (repeat	(setq i (sslength s))
      (setq	e (ssname s (setq i (1- i)))
    	l  (cons (cons e (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget e)))) l)
    (setq l (vl-sort l ''((a b) (< (caaddr a) (caaddr b)))))
    (foreach x (mapcar '(lambda (a b) (foreach x '(2 3) (setq a (subst (list b (cadr (nth x a))) (nth x a) a))) a)
    		   l
    		   (foo (mapcar 'caaddr l) d)
      (entmod (append (vl-remove-if '(lambda (x) (= (car x) 10)) (entget (car x)))
    		  (mapcar '(lambda (x) (cons 10 x)) (cdr x))
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  2. #12
    Full Member
    Using
    AutoCAD 2014
    Join Date
    Dec 2010
    Posts
    81
    Default
    cool, that is useful
Similar Threads
  1. How to increase space between objects?
    By rlcad in forum AutoCAD Beginners' Area
    Last Post: 8th Mar 2017, 11:47 am
  2. how can I plot from multiple paper space at once?
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2011, 05:12 pm
  3. Replies: 10
    Last Post: 14th Sep 2010, 10:24 am
  4. Having multiple LTS in paper space
    By chubster41 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Sep 2006, 06:16 pm
  5. multiple printing from model space
    By louislbernstein in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jul 2006, 05:10 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
