Aftertouch Posted June 18, 2018 Share Posted June 18, 2018 Hello all, Is it possible to make certain objects associated with each other? For example: I pick two points. A line is drawn between those points. A block is placed on the end of the line. All the above i can code without any problem... But... Now when i move this block, i want the end of that line to move with it... Would this be possible? Quote Link to comment Share on other sites More sharing options...
rlx Posted June 18, 2018 Share Posted June 18, 2018 (edited) good place to start : http://www.lee-mac.com/associativecenterlines.html or here : http://www.ductisoft.com/ Edited June 18, 2018 by rlx Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 19, 2018 Share Posted June 19, 2018 Maybe an idea if you set up a dimension style that is a line only everything else turned off and make it associate with the two points. Quote Link to comment Share on other sites More sharing options...
Aftertouch Posted June 19, 2018 Author Share Posted June 19, 2018 Thanks for the suggestions, I managed to build something i needed. :-) Instead of making objects associative, i used a command reactors (command start and object modified) to get the old location of the block and the new location of the block. :-) Quote Link to comment Share on other sites More sharing options...
