Gali Posted June 28, 2018 Share Posted June 28, 2018 Hi every one . I made a drawing . When I finished it I discovered that I didn't use the right units. I was inches in the file , but I should have used meters . what is the best way to correct this ? Thanks in advance Gali Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 28, 2018 Share Posted June 28, 2018 Did you just try changing "units" "metres", did you do lots of dimensioning ? What changed ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 28, 2018 Share Posted June 28, 2018 You could use the -DWGUNITS command. Yes, the dash is required. Quote Link to comment Share on other sites More sharing options...
Gali Posted June 28, 2018 Author Share Posted June 28, 2018 Thank you all I didn't do dimensions . but all lines have been done by typing numbers . I it just to go to > format > units > (and choose units from the drop down menu ) ? no factor to multiply ? Quote Link to comment Share on other sites More sharing options...
rkent Posted June 28, 2018 Share Posted June 28, 2018 Thank you all I didn't do dimensions . but all lines have been done by typing numbers . I it just to go to > format > units > (and choose units from the drop down menu ) ? no factor to multiply ? Please see post #3 Quote Link to comment Share on other sites More sharing options...
