acad1985 Posted July 3, 2018 Share Posted July 3, 2018 Hi All, Anyone know how to change all the objects to White colour except red colour object through lisp. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted July 3, 2018 Share Posted July 3, 2018 Try the following : (vl-load-com) (defun c:test (/ *error* c_doc ss) (defun *error* ( msg ) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred."))) (princ) );_end_*error*_defun (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) ss (ssget "_X" '((67 . 0))) ) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (vlax-for x (vla-get-activeselectionset c_doc) (if (and (vlax-property-available-p x 'color T) (/= (vlax-get x 'color) 1)) (vlax-put x 'color 7) );end_if );end_for (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-endundomark c_doc)) );end_defun IMPORTANT NOTE: THIS CODE WILL CHANGE THE COLOR OF ALL MODELSPACE ENTITIES ONLY, AND WHERE THE ENTITY HAS A WRITEABLE COLOR PROPERTY. THIS INCLUDES ENTITIES ON LAYERS WHERE THE LAYER COLOUR IS RED, AND THE ENTITY COLOR IS SET TO BYLAYER. IT DOES NOT CHANGE THE COLOR OF INDIVIDUAL ENTITIES WITHIN BLOCKS, ONLY THE COLOR OF THE BLOCK ITSELF. Quote Link to comment Share on other sites More sharing options...
acad1985 Posted July 3, 2018 Author Share Posted July 3, 2018 Hi dlanorh, Thanks for your quick reply. Your code was worked perfectly. Thank you so much. Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 4, 2018 Share Posted July 4, 2018 Heres another vanilla: (defun C:test ( / SS i ) (if (setq SS (ssget "X" '((-4 . "<>")(62 . 1)))) (repeat (setq i (sslength SS)) (entmod (append (vl-remove-if ''((x)(member (car x) '(420 430))) (entget (ssname SS (setq i (1- i))))) '((62 . 7)))) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
rlx Posted July 4, 2018 Share Posted July 4, 2018 Heres another vanilla: (defun C:test ( / SS i ) (if (setq SS (ssget "X" '((-4 . "<>")(62 . 1)))) (repeat (setq i (sslength SS)) (entmod (append (vl-remove-if ''((x)(member (car x) '(420 430))) (entget (ssname SS (setq i (1- i))))) '((62 . 7)))) ) ) (princ) ) is vl-remove-if vanilla? , mmm , just tasting it now ... mmm , no , it's Quote Link to comment Share on other sites More sharing options...
steven-g Posted July 4, 2018 Share Posted July 4, 2018 (edited) Forgive me butting in (Lisp noob), I'm probably way of course here but what is wrong with this, serious question! it works but probably misses some important detail and I'd like to know if I might be heading in the wrong direction with this, hence the "twit" unless you speak dutch "te wit" or "too white" translated. (defun C:twit () (command "chprop" (ssget "x" '((-4 . "<>") (62 . 1))) "" "c" "white" "") ) Edited July 4, 2018 by steven-g @rlx oops indeed (EDITED) Quote Link to comment Share on other sites More sharing options...
rlx Posted July 4, 2018 Share Posted July 4, 2018 (62 . 7) = white maybe? also , ssget might return nil so : (if (setq ss (ssget ....)) (command .....)) Quote Link to comment Share on other sites More sharing options...
rlx Posted July 4, 2018 Share Posted July 4, 2018 not too good with ssgetfilters myself , not like the big guys anyway but I'm not sure about the "" so time to do a little brain update... but just tried something like this to change all lines , who don't have color white (7) to red (1) (if (setq ss (ssget "x" '((0 . "LINE") (-4 . "<NOT") (62 . 7)(-4 . "NOT>")))) (command "._chprop" ss "" "c" "red" "")) Quote Link to comment Share on other sites More sharing options...
steven-g Posted July 4, 2018 Share Posted July 4, 2018 also , ssget might return nil so : Is that something you normally consider, surely if it returns nil then nothing happens or are there cicumstances when this could cause errors. PS I fixed the code above Quote Link to comment Share on other sites More sharing options...
rlx Posted July 4, 2018 Share Posted July 4, 2018 Is that something you normally consider, surely if it returns nil then nothing happens or are there cicumstances when this could cause errors. PS I fixed the code above in programming lisp you always have to be prepared for 'de worst' , that no object is found to match your (ssget) filter. Someone can say yes on your question , or no , but also nothing ... and nothing can also be an answer... Quote Link to comment Share on other sites More sharing options...
dlanorh Posted July 4, 2018 Share Posted July 4, 2018 Forgive me butting in (Lisp noob), I'm probably way of course here but what is wrong with this, serious question! it works but probably misses some important detail and I'd like to know if I might be heading in the wrong direction with this, hence the "twit" unless you speak dutch "te wit" or "too white" translated. (defun C:twit () (command "chprop" (ssget "x" '((-4 . "<>") (62 . 7))) "" "c" "white" "") ) Absolutely nothing wrong with the code at all. I would probably change the "x" to "_x" to force the english version as insurance against potential problems in different languages. "chprop" however, as i understand it, will only work on entities in the current space, whereas the vanilla/visual lisp versions aren't bound by this. If I remove the '((67 . 0)) [modelspace entities only] filter from my code it will process all entities on all tabs in paperspace. Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 4, 2018 Share Posted July 4, 2018 is vl-remove-if vanilla? , mmm , just tasting it now ... mmm , no , it's I remember once Marko_Ribar told(wrote) me that not all vl-* functions are from activex (somewhere here on the forum). But I'm mistaken them just like you.. soo If I had to write that in vanilla for sure, I'd substitute: (entmod (append (vl-remove-if ''((x)(member (car x) '(420 430))) (entget (ssname SS (setq i (1- i))))) '((62 . 7)))) with: (entmod (append (apply 'append (mapcar ''((x) (cond ( (member (car x) '(420 430)) ()) ; note, () = nil ( (list x) ) ) ) (entget (ssname SS (setq i (1- i)))) ) ) '((62 . 7)) ) ) Quote Link to comment Share on other sites More sharing options...
rlx Posted July 4, 2018 Share Posted July 4, 2018 (edited) You're making me thirsty Grrr haha Even though many cases your code can be shorter and cleaner using vl- functions , just using vanilla has it's advantages. Added a for example a core console option to my batch utility and this only works with vanilla lisp and also often vanilla is faster than some of the vl-functions Edited July 4, 2018 by rlx Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 4, 2018 Share Posted July 4, 2018 Even though many cases your code can be shorter and cleaner using vl- functions , just using vanilla has it's advantages. Added a for example a core console option to my batch utility and this only works with vanilla lisp and also often vanilla is faster than some of the vl-functions Yea, its no secret that vanilla is faster. Shorter - perhaps? Cleaner? - my definition for cleaner is to structure the whole code into 'blocks', such as functions/subfunctions with a good formatting. So when its time to maintain you just have to focus on the certain block of the code. I admire your ideas(codes), although I have alot of other stuff to learn ATM but at first I'm trying to finish my architectural projects, DOH! Quote Link to comment Share on other sites More sharing options...
rlx Posted July 4, 2018 Share Posted July 4, 2018 Yea, its no secret that vanilla is faster. Shorter - perhaps? Cleaner? - my definition for cleaner is to structure the whole code into 'blocks', such as functions/subfunctions with a good formatting. So when its time to maintain you just have to focus on the certain block of the code. I admire your ideas(codes), although I have alot of other stuff to learn ATM but at first I'm trying to finish my architectural projects, DOH! We are way past the point you can learn anything new from me when I look at some your code this past year. Don't have enough time to get it through my thick skull any more haha. Also in the summer time I usually don't do as much coding so each winter(ish) time is a new startup for me. Good luck with your architectural project. Workday is done and now have to face the more grim task of having diner with oldest daughter & family ;-) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 4, 2018 Share Posted July 4, 2018 FWIW, here's another way to remove items from a list using Vanilla AutoLISP: (defun remove ( x l ) (apply 'append (subst nil (list x) (mapcar 'list l))) ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 4, 2018 Share Posted July 4, 2018 FWIW, here's another way to remove items from a list using Vanilla AutoLISP:(defun remove ( x l ) (apply 'append (subst nil (list x) (mapcar 'list l))) ) Nice one, Lee! It can substitute the vl-remove function. We are way past the point you can learn anything new from me I've got some stored stuff in my archive from your posted codes, that I still have to chew up. when I look at some your code this past year. Don't have enough time to get it through my thick skull any more haha. Nah, its just that my coding style is alot different from yours - I'm sure you'll get it when you start focus on the individual blocks of the code. Good luck with your architectural project. Thanks! Workday is done and now have to face the more grim task of having diner with oldest daughter & family ;-) Wish you have(had) a great time there! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted July 5, 2018 Share Posted July 5, 2018 FWIW, here's another way to remove items from a list using Vanilla AutoLISP:(defun remove ( x l ) (apply 'append (subst nil (list x) (mapcar 'list l))) ) Nice Lee .. check this out with a list of 7200 items REMOVE Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (REMOVE 1 (QUOTE (1 1 1 3 4 5 6 11 1...).....1469 / 5.18 <fastest> (VL-REMOVE 1 L)..............................7610 / 1.00 <slowest> Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 5, 2018 Share Posted July 5, 2018 Wow, that's quite surprising. Quote Link to comment Share on other sites More sharing options...
rlx Posted July 5, 2018 Share Posted July 5, 2018 there's lots of still 'good old stuf' around http://autocad.xarch.at/lisp/goodies.html Quote Link to comment Share on other sites More sharing options...
