Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Super Member
    not applicable
    Jun 2016
    686
    I can 'connect the dots' in the 2nd picture of the OP with several more complex concave hulls...
    BricsCAD 18
  2. #12
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,290
    Yes BIGAL, but you must remove additional triangles and then recreate boundary and that's all fine if points are random... Triangulation works well only if TIN (Triangular Irregular Network), and OP's picture is grid like... For that I suppose he/she could use routine for orthogonal connections... I remember I did exactly that here on cadtutor, only difference was that instead of points there were circles... And for boundary creation from 3dFACES I also did routine (not shrinkwrap from Civil) on autodesk/customization forum for OP Carlos Gil from Venezuela - only thing was the output was 3dpolyline...
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  3. #13
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,290
    That with circles was actually dimensioning - not boundary, but you can use my code with some mods. for boundary creation...
    http://www.cadtutor.net/forum/showth...ternal-circles
    For 3dpoly around 3dfaces (after modified triangulation), try something like this... (not shrinkwrap from Civil)
    https://forums.autodesk.com/t5/visua...t/true#M365245
    HTH., M.R.
    M.R. on YouTube
  4. #14
    Junior Member
    Architectural
    AutoCAD 2014
    Jun 2017
    10
    Quote Originally Posted by marko_ribar View Post
    As far as I can tell, correctly implemented triangulation to random set of points should return convex hull boundary - not concave...
    I think you are right,If these points are equidistant,The problem is easy to solve,And the random point sets seem to have many situations
  5. #15
    Junior Member
    Architectural
    AutoCAD 2014
    Jun 2017
    10
    Quote Originally Posted by BIGAL View Post
    You are correct Marko the issue is to do with what we call long triangles have a look at this image, left is as built right is after edits and has the correct boundary.
    Looking now 3 mistakes ? Need to fix and redo, these were little tiny slivers so the correct answer is both concave and convex, then LINEWORKSHRINKWRAP. We use delete long triangles via a length factor reducing till we start erasing ones we need then it becomes maual edits. I have been told we may have a 3rd party solution from our surveyors.
    left after create triangles, middle is correct answer, right is convexhull.lsp
    it is a good solution For equidistant point sets or approximate equidistant point set
  6. #16
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,290
    Just for your info, I've added additional code here :
    http://www.cadtutor.net/forum/showth...l-circles&p=#9
    It's for grid set of points with different dx and dy spacings...
    Regards, M.R.
    M.R. on YouTube
  1. How to add a single boundary outline around multiple hatches.
    By Holybod in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Mar 2015, 03:40 pm
  2. Draw a maximum number of circles inside in polygon
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Sep 2014, 03:24 pm
  3. Maximum distance on a curve from point list
    By aaryan in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2013, 03:00 pm
  4. Replies: 1
    Last Post: 29th Aug 2011, 10:00 pm
  5. Maximum Point number
    By MARKY in forum AutoCAD General
    Last Post: 21st Apr 2010, 07:39 pm
Tags for this Thread
