Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    Rlx is it 1 dwg per sheet as well ?
  2. #12
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,058
    Quote Originally Posted by BIGAL View Post
    sadly but yes....
  3. #13
    Forum Newbie
    Mechanical
    AutoCAD 2014
    Jul 2018
    6
  4. #14
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,058
    just some lunch fun to get you started. Kept it as simple as possible. All could be done by dialog and / or automatically show all filenames in your template folder etc. Wanted to post earlier but major W10 update stopped me from doing anything for 3-4 hours.
    Code:
    (defun c:Captain_Ahap  ( / SizeList ScaleList size scale titleblockfolder titleblock)
      (vl-load-com)
      ; some shortcuts for titleblock / border sizes (without the full path)
      (setq SizeList  (list "A0" "A1" "A2" "A3" "A4-L" "A4-P")
     ScaleList (list 1 10 50 100)
     titleblockfolder "c:/temp/mytitleblockfolder/"
      (if (and (setq size  (CycleList "Choose titleblock size" SizeList))
        (setq scale (CycleList "Choose titleblock scale" ScaleList)))
          ; maybe translate size to filename first
          (cond ((eq size   "A0") (setq titleblock (strcat titleblockfolder "A0_horizondal_test.dwg")))
         ((eq size   "A1") (setq titleblock (strcat titleblockfolder "A1_horizondal_test.dwg")))
         ((eq size   "A2") (setq titleblock (strcat titleblockfolder "A2_horizondal_test.dwg")))
         ((eq size   "A3") (setq titleblock (strcat titleblockfolder "A3_horizondal_test.dwg")))
         ((eq size "A4-L") (setq titleblock (strcat titleblockfolder "A4_Landscape_test.dwg")))
         ((eq size "A4-P") (setq titleblock (strcat titleblockfolder "A4_Portrait_test.dwg")))
          (if (and titleblock (findfile titleblock) (numberp scale))
       (setvar 'expert 2) (setvar 'cmdecho 0) (setvar 'attreq 0)
       (command "-insert" titleblock (list 0 0 0) scale scale 0)
       (command "_.explode" "_L")
       (command "-purge" "B" "YourBlockName" "N")
       (command "._zoom" "e")
     (alert "Unable to insert titleblock")
    ; example1 (setq choise (CycleList "Choose titleblock size" '("A0" "A1" "A2" "A3" "A4")))
    ; example2 (setq choise (CycleList "Choose titleblock scale" '(1 10 50 100)))
    (defun CycleList (msg lst / inp loop rtn)
      (setq loop t)
      (while loop
        (princ "\nCycle list with tab or L-mouse / accept use enter,space or R-mouse / Esc or x for exit\n")
        (princ (strcat "\r" msg " <" (vl-princ-to-string (car lst)) "> : "))
        (setq inp (vl-catch-all-apply 'grread (list nil 8 0)))
        (if (vl-catch-all-error-p inp)
          (progn (princ "\nTitleblock insertion cancelled")(setq rtn nil loop nil))
            (cond
              ;tab
              ((or (equal inp '(2 9))(= (car inp) 3))
               (setq lst (append (cdr lst)(list (car lst))))
               (princ (strcat "\r" msg " <" (vl-princ-to-string (car lst)) "> : ")))
              ;enter,space,r-mouse
              ((or (equal inp '(2 13)) (equal inp '(2 32))(= (car inp) 25))
               (setq rtn (car lst) loop nil))
              ;x or X
              ((member inp '((2 88)(2 120)))(setq rtn nil loop nil))
      (terpri)
      rtn
    ; start command with (c:Captain_Ahap)
    well , (work)day is done , so I'm gone ... with the wind (or the waves since you're obviously have a fishy thing ;-)
    gr. Rlx
  5. #15
    Forum Newbie
    Mechanical
    AutoCAD 2014
    Jul 2018
    6
    Quote Originally Posted by rlx View Post
    Code:
      (vl-load-com)
      (setq loop t)
      (while loop
            (cond
              ;tab
              ;x or X
      (terpri)
      rtn
    gr. Rlx
    Thank you rlx.It works nice. will be using the 'support' folder in c instead of temp.
  1. Block creation help
    By JamFam in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Jul 2013, 07:41 am
  2. link title of file to the title block inside
    By 19cruthik68 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2012, 09:25 am
  3. Macro for Block Creation
    By nfractals in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2012, 04:04 am
  4. Block Creation
    By swfla08 in forum AutoCAD General
    Last Post: 13th May 2008, 12:30 am
  5. Dynamic Block Creation
    By Gary_W in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Mar 2007, 02:12 pm
Tags for this Thread
