Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Junior Member
    Mechanical
    AutoCAD 2016
    Jun 2018
    USA, Louisiana
    24
    Default A little help needed.......
    I have a code that I need a little help with. First things first, I am creating this to try to eliminate the use of incorrect title blocks as well as standard blocks on a project. This will be adapted to all projects so that there is more consistency throughout.
    The problem that I have run into is that I have to hit "enter" between the insertion of both blocks. And after the second block is inserted I get an unknown command error, but everything works.
    Not understanding what I have done wrong. Please see the code below and help shed some light on this for me please.
    Code:
    ;;Created by Karl E Sharp 7/3/2018
    ;;Designed to create a default project specific DWG Template with all
    ;;   project variables set. (i.e. linewght, linetypes, dimstyle, textstyle, texthieght, etc.)
    ;;Inserts project title block and all annotation blocks to be used
    ;;Sets SDI mode to 0
    ;;Turns off attribute Dialog on insertion of block
    (defun c:NDS (/ d-path)
      (setvar "dimadec" 0)                 ; Angular decimal places
      (setvar "dimalt" 0)                  ; Alternate units selected
      (setvar "dimaltd" 0)                 ; Alternate unit decimal places
      (setvar "dimaltrnd" 0.0000)          ; Alternate units rounding value
      (setvar "dimalttd" 2)                ; Alternate tolerance decimal places
      (setvar "dimalttz" 0)                ; Alternate tolerance zero suppression
      (setvar "dimaltu" 2)                 ; Alternate units
      (setvar "dimaltz" 0)                 ; Alternate unit zero suppression
      (setvar "dimapost" "")               ; Prefix and suffix for alternate text
      (setvar "dimarcsym" 0)               ; Arc length symbol
      (setvar "dimasz" 0.1875)             ; Arrow size
      (setvar "dimatfit" 3)                ; Arrow and text fit
      (setvar "dimaunit" 0)                ; Angular unit format
      (setvar "dimazin" 0)                 ; Angular zero supression
      (setvar "dimblk" "")                 ; Arrow block name
      (setvar "dimblk1" "")                ; First arrow block name
      (setvar "dimblk2" "")                ; Second arrow block name
      (setvar "dimcen" 0.25)               ; Center mark size
      (setvar "dimclrd" 256)               ; Dimension line and leader color
      (setvar "dimclre" 256)               ; Extension line color
      (setvar "dimclrt" 2)                 ; Dimension text color
      (setvar "dimdec" 4)                  ; Decimal places
      (setvar "dimdle" 0)                  ; Dimension line extension
      (setvar "dimdli" 0.0625)             ; Dimension line spacing
      (setvar "dimdsep" ".")               ; Decimal separator
      (setvar "dimexe" 0.0625)             ; Extension above dimension line
      (setvar "dimexo" 0.0625)             ; Extension line origin offset
      (setvar "dimfrac" 2)                 ; Fraction format
      (setvar "dimfxl" 1)                  ; Fixed Extension Line
      (setvar "dimfxlon" 0)                ; Enable Fixed Extension Line
      (setvar "dimgap" 0.0625)             ; Gap from dimension line to text
      (setvar "dimjust" 0)                 ; Justification of text on dimension line
      (setvar "dimldrblk" "")              ; Leader block name
      (setvar "dimlfac" 1)                 ; Linear unit scale factor
      (setvar "dimlim" 0)                  ; Generate dimension limits
      (setvar "dimltex1" "bylayer")        ; Linetype extension line 1
      (setvar "dimltex2" "bylayer")        ; Linetype extension line 2
      (setvar "dimltype" "bylayer")        ; Dimension linetype
      (setvar "dimlunit" 4)                ; Linear unit format
      (setvar "dimlwd" -1)                 ; Dimension line and leader lineweight
      (setvar "dimlwe" -1)                 ; Extension line lineweight
      (setvar "dimrnd" 0)                  ; Rounding value
      (setvar "dimsah" 0)                  ; Separate arrow blocks
      (setvar "dimscale" 1)                ; Overall scale factor
      (setvar "ltscale" 0.5)               ; Linetype scale factor
      (setvar "dimsd1" 0)                  ; Suppress the first dimension line
      (setvar "dimsd2" 0)                  ; Suppress the second dimension line
      (setvar "dimse1" 0)                  ; Suppress the first extension line
      (setvar "dimse2" 0)                  ; Suppress the second extension line
      (setvar "dimsoxd" 0)                 ; Suppress outside dimension lines
      (setvar "dimtad" 1)                  ; Place text above the dimension line
      (setvar "dimtdec" 4)                 ; Tolerance decimal places
      (setvar "dimtfac" 1)                 ; Tolerance text height scaling factor
      (setvar "dimtfill" 1)                ; Text background enabled
      (setvar "dimtfillclr" 0)             ; Text background color
      (setvar "dimtih" 0)                  ; Text inside extensions is horizontal
      (setvar "dimtix" 0)                  ; Place text inside extensions
      (setvar "dimtm" 0)                   ; Minus tolerance
      (setvar "dimtmove" 0)                ; Text movement
      (setvar "dimtofl" 0)                 ; Force line inside extension lines
      (setvar "dimtoh" 0)                  ; Text outside horizontal
      (setvar "dimtol" 0)                  ; Tolerance dimensioning
      (setvar "dimtolj" 0)                 ; Tolerance vertical justification
      (setvar "dimtp" 0)                   ; Plus tolerance
      (setvar "dimtsz" 0)                  ; Tick size
      (setvar "dimtvp" 0)                  ; Text vertical position
      (setvar "dimtxsty" "standard")       ; Text style
      (setvar "dimtxt" 0.09375)            ; Text height
      (setvar "dimtzin" 0)                 ; Tolerance zero suppression
      (setvar "dimupt" 0)                  ; User positioned text
      (setvar "dimzin" 3)                  ; Zero suppression
      (command "dimstyle" "save" "standard" "y")
      (command "style" "standard" "romans" 0.09375 1 0 "no" "no" "no")
      (command "linetype" "load" "center2" "" "")
      (command "linetype" "load" "hidden2" "" "")
      (command "linetype" "load" "phantom2" "" "")
      (command "layer" "m" "DIM" "c" "1" "DIM" "")
      (command "layer" "m" "TEXT" "c" "2" "TEXT" "lt" "continuous" "TEXT" "")
      (command "layer" "m" "CENTER" "c" "1" "CENTER" "lt" "center2" "CENTER" "")
      (command "layer" "m" "HIDDEN" "c" "2" "HIDDEN" "lt" "hidden2" "HIDDEN" "")
      (command "layer" "m" "MATCHLINE" "c" "3" "MATCHLINE" "lt" "phantom2" "MATCHLINE" "")
      (command "layer" "m" "EQUIP" "c" "3" "EQUIP" "lt" "continuous" "EQUIP" "")
      (command "layer" "m" "LABEL_PLATE" "c" "3" "LABEL_PLATE" "lt" "continuous" "LABEL_PLATE" "")
      (command "layer" "m" "BACKGROUND" "c" "9" "BACKGROUND" "lt" "continuous" "BACKGROUND" "")
      (command "layer" "m" "SYMBOLS" "c" "3" "SYMBOLS" "lt" "continuous" "SYMBOLS" "")
      (command "layer" "m" "VIEWPORT" "c" "7" "VIEWPORT" "plot" "n" "VIEWPORT" "")
      (command "layer" "s" "0" "")
      (command "LUNITS" "4")
      (command "LUPREC" "5")
      (setvar "SDI" 0)                     ; Turns SDI mode off
      (setvar "attdia" 0)                  ; Turns the attribute edit dialog box off for block insertion
      (setvar "attreq" 1)
      (initdia 0)
      (setq filename "S:\\folder-1\\subfolder-1\\filename")
      (if
        (= 0 (getvar "SDI"))
          (command "-insert" "S:\\folder-1\\subfolder-1\\filename" '(0. 0. 0.) "" "" ""))   ; Inserts Client Border
      (while (= (logand (getvar "cmdactive")1)1)
        (command ""))
        (initdia)
       (setq filename "S:\\folder-2\\subfolder-2\\filename")
      (if
          (command "-insert" "*S:\\folder-2\\subfolder-2\\filename" '(36. 0. 0.) "" "" )) ; Inserts Company Border with standard annotation blocks
        (command ""))
        (initdia)
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,059
    just @ first glance, haven't tested your code, but you use while cmdactive command pause...
    Junior Member
    Mechanical
    AutoCAD 2016
    Jun 2018
    USA, Louisiana
    24
    Completely new to this. What should I do instead? I tried removing the command pause and it freezes...... Oh this is making my brain pan hurt :/
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,059
    Quote Originally Posted by KESHAR View Post
    Well I'm actually feeding my brain with a little anti-freeze , hik ;-)
    but maybe (command "") in stead of (command pause)?
    Also (again without testing) , just from memory (which is slowly getting foggy) , when you insert a block with prefix * , do you still have the same number of prompts? I'm not entirely sure without trying , but I vaguely remember the standard prompts will ask for separate scale for x and y and the other just one scale factor for both.
  5. #5
    Junior Member
    Mechanical
    AutoCAD 2016
    Jun 2018
    USA, Louisiana
    24
    Thanks.... that worked for the issue between the insertions..... not sure about the number of prompts for "*" on insertion......gonna check something.....
  6. #6
    Junior Member
    Mechanical
    AutoCAD 2016
    Jun 2018
    USA, Louisiana
    24
    vundaba!!!! Thanks for the assistance RLX...... I had one to many quotes on the second insertion....I have edited the above code with the corrections. Trying to get a better handle on all of this so I can truly say that I have learned something new and in the process help out somewhere along the way, and hopefully make my life easier.
  7. #7
    Junior Member
    Mechanical
    AutoCAD 2016
    Jun 2018
    USA, Louisiana
    24
    Just out of curiosity, is there a way to condense this down to less coding?
  8. #8
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,059
    I'm sure you can compress the code a lot with using mapcar etc and most if not all command functions can be replaced with vla functions. But this would save you a few micro seconds , hell maybe a whole second... big deal. if it works it works. It's 1 in the morning for me so I wont be doing any coding no more for a wile
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    About the only saving is in your make layers can be done as say read file but you have so few is it worth it. There are other ways also make a list of ((layname1 col LT)(layname2 col lt)) and so on reading the list and making, 3rd use a make layer defun (laych "Background" 9 "Continuous), in my case this is a library function that checks if layer exists ignore else make it.
  10. #10
    Senior Member
    Surveying
    dlanorh's Discipline Details
    Geospatial Engineer
    Surveying
    AutoCAD 2012
    Aug 2017
    UK/Bundesrepublik Deutschland
    130
    Code:
      (initdia 0)
      (if (= 0 (getvar "SDI"))
        (command "-insert" filename '(0. 0. 0.) "" "" ""))   ; Inserts Client Border
        (command ""))
      (initdia)
      (setq filename (strcat"*" "S:\\folder-2\\subfolder-2\\filename"))
        (command "-insert" filename '(36. 0. 0.) "" "" )) ; Inserts Company Border with standard annotation blocks
        (command ""))
      (initdia)
       (princ) )
    The red items in your code are never used. I have subsituted the variable "filename" in the command insert calls. If you want to go with the hard coded file name string in the command insert calls, then the two red lines of code can be removed. If not then you can put it in a while loop
    Code:
      (initdia 0)
      (setq filenames (list (cons "S:\\folder-1\\subfolder-1\\filename" '(0. 0. 0.))
                            (cons "*S:\\folder-2\\subfolder-2\\filename" '(36. 0. 0.))
      (foreach f_name filenames
          (command "-insert" (car f_name) (cadr f_name) "" "" "")
          (command "")
        (initdia)
  1. Help needed!
    By bavdeyka in forum Autodesk Inventor
    Last Post: 5th Feb 2017, 09:56 pm
  2. Help needed
    By the condition in forum SolidWorks
    Last Post: 15th Aug 2012, 04:13 pm
  3. 3D help needed
    By TheNewGuy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Mar 2009, 08:01 pm
  4. Help needed
    By ChrisN in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2007, 05:35 pm
  5. Help Needed
    By Rebbeca in forum AutoCAD General
    Last Post: 30th Oct 2006, 02:31 pm
