Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Full Member
    Electrical
    AutoCAD 2016
    Sep 2017
    Townsville, NQ, Australia
    41
    Default Cannot print added text
    In the drawing attached below, there are 4 lines of text shown above the title. The last 2 lines were added recently.
    When I print out the drawing from the Layout1 view, the last two lines of text ( specifying the dimensions of the sides and the base) do not appear on the printed output.
    Similarly, if I export the drawing in a .pdf format, the two lines of text are also missing.
    Also, the bottom two lines of text do not appear in the Print Preview.
    I have tried double clicking on the Layout1 page, saving again, zooming, shutting down and restarting the program, to no avail.
    Can anyone please advise why this might be happening, and how to overcome it?
    Super Member nukecad's Avatar
    nukecad's Computer Details
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    NW Cumbria (English Lake District)
    714
    I can't open your drawing on this laptop to check, but the most common cause of this is that the text is on 'layer 0' which never plots.
    Move it to a different layer.
    Second most common is that the text is on another layer that has been set not to plot.
    Again move it to a different layer, or turn on plotting for the layer that it is on.
    Third most common, if this text is in model space then maybe those two added lines have 'strayed' outside the paperspace viewport?
    Turn on the viewport outline in paperspace and check.
    If the text is falling over the boundry then make the viewport bigger, or move the text so it is fully inside the viewport.
    There may be another cause, but as I say I can't open the drawing on this laptop and the above are the three most common.
    *** Out of Beer Error ->-> Recovering Memory***
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    I can't open it either since I am at home, but maybe the text is color 255, the "other" white that does not change with the background.
    And layer 0, (zero) does plot, unless it is set not to. It is DEFPOINTS that doesn't plot, nor should it be used to draw or place any objects on so they won't plot. It is a system layer that should be left alone.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    That text currently has a colour 255 and is on layer DIM.
    Set the colour to Bylayer, unless you want it not to print.
  5. #5
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    714
    Quote Originally Posted by Dana W View Post
    Thanks for the correction, like everyone else my brain sometimes gets in front of itself.
    (It was always 'good practice' never to draw anything on layer 0 and have it turned off for plotting. Of course what is 'good practice' changes over the years as AutoCAD versions change).
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by nukecad View Post
    It's still good practice to not use it for drawing, but to inform the novices reading...
    Creating geometry in blocks on Layer 0 is good because they will take on the properties of any other layer the block is inserted on. You can include geometry in blocks on other layers too, but those object properties will not change when inserted on other layers.
  7. #7
    Full Member
    Electrical
    AutoCAD 2016
    Sep 2017
    41
    Thanks for your ideas and suggestions, folks, I really apprecaite them. I have changed the colour to By Layer, and still the bottom 2 lines do not print.
    I have attached print screens of the various pictures which may shed some light:
    1. Print Preview
    2. Properties of the upper 2 lines of text
    3. Properties of the lower 2 lines of text ( these were a separate multiline text addition, not an extension of the upper text)
    4.The Layout1 view, showing Viewport boundary
  8. #8
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,317
    As Eldon mentioned, your Mtext is set to color 255,255,255, see image below.
    Double click on the Mtext, highlight all the text and then change it to ByLayer where I have indicated within the red box. Once you do this, your Mtext should change to red and you should see it when you plot.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  9. #9
    Full Member
    Electrical
    AutoCAD 2016
    Sep 2017
    41
    Many thanks for doing this, Cad64, very much appreciated. As you can see in the post immediately before yours, I had changed things from my original .dwg posted by using the Outline layer ( not the red Dim layer) and changed the Mtext by selecting the two lines of text, going into Properties and changing the Colours to By Layer. Obviously that did not work, as I still could not see the 2nd row of text. Strange!!
    In the end I changed it in the Text Editor as you indicated, and the two lines of print appeared in Print Preview. YESS!!!!!
    All this problem printing lines came about because I entered the lines of text while in the Dim layer
  10. #10
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    If you look at the Content section of the properties of the affected text, you can see some format statements before the actual text {\C0,\c16777215; That gives a clue that something is amiss.
  1. I cannot print text inside my autocad print out everything else is coming
    By kiranvarghese1 in forum AutoCAD Drawing Management & Output
    Last Post: 18th Feb 2016, 03:08 am
  2. Cannot Print Colour, Crunched up Text, Restricted Print Field
    By D1-Xen in forum AutoCAD Drawing Management & Output
    Last Post: 14th May 2012, 06:46 am
  3. newly added objects won't print
    By bragsdale in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2010, 04:28 pm
  4. Hatch Around Text Added Later
    By Bill Tillman in forum AutoCAD General
    Last Post: 10th Oct 2009, 02:41 am
  5. Text added in paperspace hides behind viewport
    By malcolm_macaulay in forum AutoCAD Beginners' Area
    Last Post: 7th Mar 2007, 03:12 pm
