Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,246
    Hi Grrr,
    I think you need to exclude the VIEWPORT object from the selection set since you have used the entmod function besides that, you don't need to search if the target layer is found or existed since the cons function could create that target layer name with default values.
  2. #12
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Please read the Code Posting Guidelines and have your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  3. #13
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Quote Originally Posted by Tharwat View Post
    Hi Grrr,
    Hi Tharwat,
    Thanks for the advices.. I have one question regarding the VIEWPORT:
    Wheres a case for the user to select a VIEWPORT object? When working in paperspace (my guess) ?
    I always work in modelspace, so I never regarded the possibility for this issue.
    BTW for the second remark, I actually don't look if the targed layer already exists - just making sure if OP provides list of dotted pairs:
    Code:
    '( ; The routine will skip entmod'ing "Layer1"
      ("obj2" . "obj1")
      ("dim" . "0")
      ("Layer1")
    But I agree its a bit inefficient to entmod with the same layer.
  4. #14
    Junior Member
    Structural
    AutoCAD 2017
    Jun 2018
    17
    will take care of this next time thank you for your reminder.
  5. #15
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    Quote Originally Posted by Grrr View Post
    Hi Tharwat,
    We can't guess that all users work from / in Model space.
    Agree with that but that would ignore moving objects to targeted layer if its not existed and that is the point.
    Hope that my comment did not make any confusion.
  6. #16
    Junior Member
    Structural
    AutoCAD 2017
    Jun 2018
    17
    Hi Grrr,
    tharwat if you could help on sathish's code why it is not working on my system ? any thoughts ?
    test
  7. #17
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    Solitechcadsolutions, you need to describe your goal of the program very clearly to all members whom wanting to help you and write the correct codes for that purpose.
    For instance;
    What are the objects that you are trying to move them to that new layer name?
    Would you like to select certain objects or let the program select them all?
    Do you have the objects on unlocked layers?
    And so on.
  8. #18
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,593
    I agree with the use of an association list, but the code could be greatly simplified, for example -
    Code:
    (defun c:laymap ( / enx idx lay map sel )
        (setq map
            (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x)))
                    ("obj2" . "obj1")
                    ("dim"  . "0")
        (if (setq sel (ssget "_:L" (append '((-4 . "<OR")) (mapcar '(lambda ( x ) (cons 8 (car x))) map) '((-4 . "OR>")))))
            (repeat (setq idx (sslength sel))
                (if (setq idx (1- idx)
                          enx (entget (ssname sel idx))
                          lay (cdr (assoc (strcase (cdr (assoc 8 enx))) map))
                    (entmod (subst (cons 8 lay) (assoc 8 enx) enx))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  9. #19
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Nice one Lee,
    I didn't realise you could filter the layers like that, with ignoring the case of their names!
  10. #20
    Junior Member
    Structural
    AutoCAD 2017
    Jun 2018
    17
    thank you lee and grr that codes are working nicely for me ....
    Great
  1. Convert to autolisp code
    By gS7 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Feb 2013, 08:51 am
  2. Select one object/entity, gripped all same entity within the layer
    By Ahmeds in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2012, 01:40 pm
  3. How to convert to G-code?
    By nainuad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Sep 2008, 03:53 am
  4. Replies: 1
    Last Post: 26th Jun 2008, 06:32 am
  5. How to convert the VBA code to VB?
    By fenny in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jan 2005, 08:41 am
