Results 1 to 3 of 3
    Full Member
    AutoCAD 2008
    Aug 2006
    ellesmere port, england
    96
    Default Installation Problems
    can anyone help, i can not install inventor on my laptop through installation i get a warning message that reads
    ERROR 1305 reading from d\:inventor\inventor11\samples\models\parts\hairdr yer\hairdryer ipt verify that the file exists and you can access it. and then it asks to retry or cancel installation.
    keep retrying and re-installing but keep getting same message
    can anyone advise what problem is
    regards
    into any cad design
    love using 3D
    love using solidworks
    learning inventor
    Senior Member zars's Avatar
    zars's Computer Details
    Windows Xp Profesional Service Pack 3
    Dell Optiplex 755
    Intel D946GZIS
    Intel Core2Duo 2.13 GHz
    1 GB Kingston DDR2 333 Mhz
    Sata 300 Gb Western Digital
    Dell 17''
    AutoCAD 2007
    May 2006
    LZC, Michoacan, Mexico.
    464
    Well, the system can't read the file so it seems to me that your cd can be damaged so try to clean it up or try to copy everything from your CD to your C drive and install from there.
    There are only 2 things which are infinite... the universe and the human stupidity.
    "Life is not the amount of breath you take, it's the moments that take your breath away"
    Senior Member
    Inventor 2008
    Sep 2006
    Auburn, WA
    192
    I don't remember if there is an option for this or not but the hairdryer model is just part of the tutorial sample parts. You may be able to skip installing this part of the program by doing a custom install. First though, as zars said, try cleaning the disk or copying it to your HD (although if the disk is corrupted you wont be able to do this either) and if neither of those things work contact your VAR and get them to send you a new disk.
    David
  1. Re-Installation of Cad
    By scoffagus in forum AutoCAD Beginners' Area
    Last Post: 18th May 2010, 12:10 am
  2. Autocad 2007 installation
    By pab006 in forum Software & Licensing
    Last Post: 10th Apr 2006, 11:51 pm
  3. AutoCAD installation problems
    By Jonosss in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2005, 08:06 am
  4. express tools installation
    By jt6572 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Feb 2005, 01:59 am
  5. After installation Viz 4 not working
    By Hakan Kisacik in forum 3ds Max General
    Last Post: 31st Oct 2002, 09:56 pm
