+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2018
    Posts
    6
    Default Block Description to Multileader
    Hi Designers,
    I would like to have a lisp that reads the Description of a Block and shows it on a Multileader so then you don't have to type in the Text once a Block is registered.
    I know this topic was covered in an much older post before - almost 10 years ago - but I put hours experimenting with the Lisp in different ways and still couldn't get it to work 100%.
    http://www.cadtutor.net/forum/showth...ltileader-text
    Does anyone have the solution to this?
  2. #2
    Full Member
    Using
    AutoCAD 2014
    Join Date
    Dec 2010
    Posts
    95
    Default
    Here is what I wrote:
    - the client selects a block (I assume it has a description, I assume the client clicks on a block ... no anti dummy protection)
    - the client must now draw the MLeader: two points: arrow head + leader landing
    - The routine will fill in the caption, being the description of the block.
    Command: SAD (pun maybe intended, although it's just an abbreviation)
    Code:
    (defun getBlockProperties ( #Entsel / )
          (setq #Entsel   (vlax-ename->vla-object (car #Entsel))
                ;; insertion point
                #InsPoint (vlax-safearray->list
                            (vlax-variant-value
                              (vla-get-InsertionPoint #Entsel)
                            ) ;_ vlax-variant-value
                          ) ;_ vlax-safearray->list
                ;; block name
                #Name     (vla-get-name #Entsel)
                ;; block description
                #Desc     (vla-get-comments
                            (vla-item
                              (vla-get-blocks
                                (vla-get-activedocument (vlax-get-acad-object))
                              ) ;_ vla-get-blocks
                              #Name
                            ) ;_ vla-item
                          ) ;_ vla-get-comments
          ) ;_ setq
      (list #Name #InsPoint #Desc)
    ;; create Mleader with caption.
    (defun wmt (caption / )
      ;;(vl-cmdf "_.MLEADER" PAUSE PAUSE "" "_.TEXTEDIT" "_L")
      (vl-cmdf "_.MLEADER" PAUSE PAUSE  caption)
    ;; Select And get Description
    (defun c:sad ( / desc)
      (setq desc (nth 2 (getBlockProperties (entsel "\nSelect a block: "))))
      (princ "\nNow draw the MLeader:\n")
      (wmt desc)
    Happy with this?
  3. #3
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2018
    Posts
    6
    Default
    Almost !
    It identifies the Description, but won't fill in the caption.
  4. #4
    Luminous Being Tharwat's Avatar
    Discipline
    Mechanical
    Tharwat's Discipline Details
    Occupation
    MEP AutoCAD Draughtsman
    Discipline
    Mechanical
    Details
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    Using
    AutoCAD 2017
    Join Date
    Oct 2009
    Location
    Great Syria , Living in Abu Dhabi
    Posts
    6,246
    Default
    The simplest I guess.
    Code:
    (defun c:d2ml ( / s d)
      (and (princ "\nPick a block :")
           (setq s (ssget "_+.:S:E" '((0 . "INSERT"))))
           (or (setq d (cdr (assoc 4 (entget (tblobjname "BLOCK" (cdr (assoc 2 (entget (ssname s 0)))))))))
               (alert "Block does not have a description <!>")
           (vl-cmdf "_.Mleader" "\\" "\\" d)
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2018
    Posts
    6
    Default
    Same result.
    I don't know why it won't put in the Description..
  6. #6
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    AutoCAD 2017
    Join Date
    Oct 2009
    Location
    Posts
    6,246
    Default
    Quote Originally Posted by AlexP View Post
    Same result.
    Can you post a drawing including the block?
  7. #7
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2018
    Posts
    6
    Default Dwg
    See attached.
  8. #8
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    AutoCAD 2017
    Join Date
    Oct 2009
    Location
    Posts
    6,246
    Default
    Just this a go and let me know.
    Code:
    (defun c:d2ml ( / s d l n e)
           (setq l (entlast))
           (vl-cmdf "_.Mleader" "\\" "\\" "")
           (and (not (= l (setq n (entlast))))
                (entmod (subst (cons 304 d) (assoc 304 (setq e (entget n))) e))
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2018
    Posts
    6
    Default
    You are a Legend Tharwat !!
    It's works perfectly, many thanks for that !
    And you Emanuel for giving it a go, I appreciate it.
  10. #10
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    AutoCAD 2017
    Join Date
    Oct 2009
    Location
    Posts
    6,246
    Default
    Thanks for the nice words AlexP.
    You are welcome anytime.
Similar Threads
  1. Replies: 0
    Last Post: 23rd May 2016, 12:22 pm
  2. Block Description Property
    By guitarguy1685 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th May 2016, 04:20 pm
  3. How to add Block Description
    By bijoyvm in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Apr 2011, 08:57 am
  4. Edit Block Description
    By AQucsaiJr in forum AutoCAD General
    Last Post: 19th Oct 2009, 09:27 pm
  5. block description in vba
    By Jaap in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jan 2009, 02:51 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
