Results 1 to 10 of 10
    Full Member
    Demesne's Computer Details
    Windows 7 x64
    Lenovo ThinkPad P51
    Intel Core i7 2.7GHz
    64GB
    NVIDIA Quadro M2000M
    500GB SSD
    2TB SSD
    Multiple
    Civil
    Demesne's Discipline Details
    Land Surveyor
    Civil
    AutoCAD 2018
    Mar 2009
    England
    46
    Default As-Built Deviation
    Hello
    I've been trying unsuccessfully to modify ASMI's Deviation_Tag routine which produces x,y deviations between two picked points. Rather than have the results displayed with arrows I'd like to have them displayed in a box with a +/- prefix and also have the option to set a scale when starting the lisp.
    ASMI's Deviation_Tag.lsp references four drawing files that contain the arrows and attributes definitions, I have created my own block (Deviation_BOX.dwg) and I can simply change the code to load this file (same file for all four quadrants - not ideal, but I'm not that clued up).
    The link above is to the original files and the attached shows my butchered effort. If anyone is able to help me with the +/- prefix and the scale I'd be most grateful.
    What would be a bonus, but not a necessity just now, would be an arrow from the closest corner of the block to the as-built point (second pick point). This could be either of the four corners depending on where the block was placed.
    I'm stuck with this one.
    Thanks
    Demesne
    Last edited by Demesne; 11th Jul 2018 at 04:55 pm. Reason: Files now in v2013 format. Deviation_BOX.dwg amended.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Have a look at this for the 4 corner arrows etc, I know in CIV3d tbm labeling is a pain.
    http://www.cadtutor.net/forum/showth...Dynamic-Blocks
    Full Member
    Windows 7 x64
    Lenovo ThinkPad P51
    64GB
    500GB SSD
    2TB SSD
    Multiple
    Civil
    Land Surveyor
    Civil
    AutoCAD 2018
    Mar 2009
    England
    46
    Hi BIGAL
    I'm not sure if I'm missing something but I couldn't find anything on that post that helped. I'm just trying to pick two points (one a design position the other an as-built) and have the deviation between the two points drawn in a box as per the Sample.dwg above. If I have missed something in the link you sent, it's probably because I'm no lisp expert.
    Thanks
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    Quote Originally Posted by Demesne View Post
    hi not every has newer version cad like yours so can't test your block.
    but IMO it should display negative by removing abs
    i.e: (rtos (abs (.....))) ; remove absolute number
    Code:
    (rtos(*(car deVal)1000)2 0)
    (rtos(*(cadr deVal)1000)2 0))
    FWIW i recall it was a bit similar 'asbuilt?' (theoretical & actual point)? without using block.
    It uses TEXTSIZE as associative scale.
    here i fixed minor 'osmode bug
    Code:
    (defun c:devtest (/ p1 p2 p3 *error* var os osaved delta _mirror s ip)
     ;sub-functions to be included here
    ;defun _mirror & defun delta
     ;to adjust scale,
     ;command: TEXTSIZE
      (defun *error* (msg)
        (if	var
          (mapcar 'setvar var osaved)
      (if (not (tblsearch "LAYER" "DIFF"))
        (vl-cmdf "-Layer" "m" "DIFF" "")
      (setq	var    '(osmode angbase angdir cmdecho clayer mirrtext)
    	osaved (mapcar 'getvar var)
    	os     (car osaved) ; or favourite osmode = 40
      (mapcar 'setvar var (list os (/ pi 2.0) 1 0 "DIFF" 0))
      (terpri)
      (while (and (setq p1 (getpoint "\rTheoretical point..       "))
    	      (setq p2 (getpoint p1 "\rActual point..            "))
    	      (setvar 'osmode 0)
    	      (setq p3 (getpoint p2 "\rPlacing arrow..           "))
        (delta p1 p2 p3)
        (setvar 'osmode os)
      (if osaved
    BIGAL will assist you if regarding Block issue, good luck
    Last edited by hanhphuc; 11th Jul 2018 at 02:22 pm. Reason: code added & fixed osmode bug
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  5. #5
    Full Member
    Windows 7 x64
    Lenovo ThinkPad P51
    64GB
    500GB SSD
    2TB SSD
    Multiple
    Civil
    Land Surveyor
    Civil
    AutoCAD 2018
    Mar 2009
    England
    46
    DWG files re-uploaded as v2013. Thanks for pointing that out. I've just migrated to a new laptop (clearly not very well).
    I've stripped out abs and reversed the two variables ppPos and bsPos so that the deviations show as from proposed to design rather than from design to proposed. This works and does show the negative symbol where needed but I'm stumped on how to put a plus symbol on there to show a positive deviation - I know that it is assumed that numbers without a sign are positive, but I just think it would look better in this instance.
    This is where I'm at:
    Code:
    ; Original code by ASMI (Deviation_Tag.LSP) - CADTutor
    ; Badly butchered by Demesne 11/07/18
    (defun c:devbox( / *error* oldEcho ppPos bsPos deVal insBl)
         (setvar "CMDECHO" oldEcho)
       ); end of *error*
       (defun +rtos (x u p)
          (strcat
    	    (if (> x 0)
    	    (rtos x u p)
       (setq oldEcho(getvar "cmdecho"))
       (setvar "CMDECHO" 0)
       (setq bsPos(getpoint "\nPick proposed position > "))
       (setq ppPos(getpoint "\nPick as-built position > "))
       (setq deVal(mapcar '- ppPos bsPos))
       (setq insBl "Deviation_BOX")
       (if
         (not(tblsearch "block" insBl))
           (if
            (setq blPath(findfile(strcat insBl ".dwg")))
    	    (command "-insert" blPath "_s" "1" pause "0"
    	 	  (+rtos(*(car deVal)1000)2 0)
    	 	  (+rtos(*(cadr deVal)1000)2 0))
            (alert(strcat "\n*** File " (strcat insBl ".dwg") " not found! *** "))
           ); end if
         ); end progn
         (command "-insert" insBl "_s" "1" pause "0"
    	      (+rtos(*(car deVal)1000) 2 0)
    	      (+rtos(*(cadr deVal)1000) 2 0))
       ); end if
      (setvar "cmdecho" oldEcho)
    ); end of c:devbox
    Last edited by Demesne; 11th Jul 2018 at 05:02 pm. Reason: Code updated to include hanhphuc suggestion.
  6. #6
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    Code:
    Code:
      (strcat (if (> x 0)
    	  (rtos x u p)
    (+rtos 10. 2 0)
    "+10"
    (+rtos -10. 2 0)
    "-10"
  7. #7
    Full Member
    Windows 7 x64
    Lenovo ThinkPad P51
    64GB
    500GB SSD
    2TB SSD
    Multiple
    Civil
    Land Surveyor
    Civil
    AutoCAD 2018
    Mar 2009
    England
    46
    Thanks hanhphuc. I've added your code to my code above. Your help is greatly appreciated.
    I'll have to have a play with trying to show an arrow from the closest corner of the box to the as-built point. Suggestions welcome
  8. #8
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    900
    Why don't you use an mleader? Here's some sample code ( assumes your current mleaderstyle has text )
    Code:
    (defun c:foo (/ p1 p2 p3 r)
      (cond	((and (setq p1 (getpoint "\nPick first point:"))
    	      (setq p2 (getpoint "\nPick second point:"))
    	      (setq r (mapcar '(lambda (x)
    				 (strcat (cond ((minusp x) "")
    					 (rtos (* x 1000) 2 0)
    			      (mapcar '- p1 p2)
    	 (entmakex (list '(0 . "line") '(8 . "deviation") '(62 . 8) (cons 10 p1) (cons 11 p2)))
    	 (setq p2 (polar p1 (angle p1 p2) (/ (distance p1 p2) 2.)))
    	 (if (setq p3 (getpoint p2 "\nSpecify leader landing location: "))
    	   (command "_.mleader" p2 p3 (strcat "E " (car r) "\\PN " (cadr r)))
  9. #9
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    no worries.
    putting arrow thanks ronjonp has shared his idea
    though ver 2007 does not have command mleader, IMO qleader could do the same.
  10. #10
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    Quote Originally Posted by ronjonp View Post
    Code:
    (defun c:foo (/ p1 p2 p3 r)....
    Nice idea. since the LINE being created, if only working in WCS i have an idea using FIELD - Line's delta property
    v2007 using qleader instead of mleader.
    [EDIT]
    since line's delta property is referenced to UCS, i.e: The deviations value can be updated while working in different UCS or WCS upon command REGEN
    - trans UCS & output 'str' to be evaluated in 'and' expression
    - Mtext justification entmod didn't work after addleader due to entlast was not MTEXT
    Code:
    (vl-load-com)
    (defun c:devtest2 ( / *error* p1 p2 p3 ex del obj str mtx )
    (setq *msps* ((lambda	(doc)
    		  (foreach x '(ActiveDocument ActiveLayout Block) (setq doc (vlax-get doc x)))
    		 (vlax-get-acad-object)
          *error*  '((msg) (princ "\n*cancel*"))
    (while
      (and	(setq p1 (getpoint "\nPick 1st point.. "))
    	(setq p2 (getpoint "\nPick 2nd point.. "))
    	(setq en (entmakex (vl-list* '(0 . "LINE") '(8 . "DEVIATION") '(62 . 8)
    			   (mapcar ''((a b)(cons a (set b (trans (eval b) 1 0)))) '(10 11) '(p1 p2))))
    	      obj (vlax-ename->vla-object en)
    	      p2 (mapcar ''((a b)  (* (+ a b) 0.5)) p1 p2)
    	(setq p3 (getpoint (trans p2 0 1) "\nSpecify leader landing location: "))
    	(setq p3 (trans p3 1 0)
    	      del (vlax-get obj 'delta)
    	      str (XY->field obj 2 0 1000 0))
    (vla-addleader *msps* (vlax-safearray-fill (vlax-make-safearray 5 '(0 . 5)) (append p2 p3 ))
    (setq mtx (vla-addmtext
    	    *msps*
    	    (vlax-3d-point p3)
    	    (* (+ 3 (apply 'max (mapcar ''((x) (strlen (rtos x 2 3))) del))) (getvar 'textsize))
    	    str
    ;;; Text justification revised using vla method
    (mapcar '(lambda (a b)(vlax-put mtx a b))
    	  '(attachmentpoint Rotation)
    	  (list (if (car (mapcar '< p2 p3))
    	    4
    	    6
    	   (- (* 2. pi) (angle '(0. 0. 0.) (getvar 'ucsxdir)))
      mtx
    acLineWithArrow
    ) ;progn
    ) ; while
    (*error* nil)
    ;;; XY->FIELD : generates quick XY point field code - hanhphuc
    ;;;obj 	- VLA object
    ;;;u 	- units 1=Scientific 2=Decimal 3=Engineering 4=Architectural 5=Fractional 6=Current
    ;;;prec - precision
    ;;;sc	- multiplier factor (credits: Inspired by Lee Mac's fieldmath)
    ;;;mode	- (Points,*Text,Arc,Circle,Ellipse & Delta ) 0=default
    ;;;	  (Line,Arc,Ellipse) 1=Startpoint,2=Endpoint
    ;V1.1: fix to support start&endpoints, maintains 5 arguments
    (defun XY->field (obj u prec sc mode / prop pfx xy )
     (setq xy  0  ;;;;user favorite prefix format default 0=E&N ,1=X&Y
           pfx (if (zerop xy)
    	     '("E " "N ")
    	     '("X " "Y ")
      (if (and (setq prop (nth mode (vl-remove nil (mapcar '(lambda (x)
    				 (if
    				  (vlax-property-available-p obj x)
    				  x
    			       '("Coordinates" "Center" "InsertionPoint" "TextPosition" "Origin" "Delta" "StartPoint" "EndPoint")
    	   (not (vlax-erased-p obj))
    	   (<= (length (vlax-get obj prop)) 3)
        (apply 'strcat
    	   (mapcar '(lambda (a b c)
    		      (strcat a
    			      "%<\\AcExpr ("(rtos (float sc) u prec)" * %<\\AcObjProp Object(%<\\_ObjId "
    			      (itoa (vla-get-objectid obj))
    			      prop
    			      " \\f \"%lu"(itoa u)"%pt"
    			      c
    			      "%pr8\">%"
    			      ") \\f \"%lu"(itoa u)"%pt"
    			      c
    			      "%qf1%pr"(itoa prec)"\">%"
    			      " \n"
    		   (if (= prop "Delta") (mapcar '(lambda(x)(strcat "d" x)) pfx ) pfx )
    		   (vlax-get obj prop)
    		   '("1" "2")
    Last edited by hanhphuc; 13th Jul 2018 at 05:21 am. Reason: fixed sub-function to support start & end points
  1. Deviation arrow LISP
    By MaT02 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Apr 2018, 07:34 am
  2. Borehole Deviation 3D drawing with Coordinates
    By BIJI SAMUEL in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Jan 2018, 12:42 pm
  3. Deviation Autolisp command
    By johnm1011 in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Nov 2014, 08:16 pm
  4. Chordal Tolerance/Triangular Deviation
    By BSouders in forum AutoCAD Drawing Management & Output
    Last Post: 7th Feb 2007, 05:08 pm
