How to pause for user input in while and run more than 1 command call
3dwannab
TWO THINGS HERE
1. How can I get the pause to be only asked once in the while loop.
2. Unknown command "MW". Press F1 for help. comes up for the last 2 commands.
CODE FOR CREATING MULTIPLE WIPEOUTS:
(defun c:mw ( /
sset
countn
n
*error*
cmde
os
smode
(defun *error* (errmsg)
(and acDoc (vla-EndUndoMark acDoc))
(and errmsg
	(not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
	(princ (strcat "\n<< Error: " errmsg " >>"))
(setvar 'cmdecho cmde)
(setvar 'osmode os)
(setvar 'selectsimilarmode smode)
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc))
(setq cmde (getvar 'cmdecho))
(setq os (getvar 'osmode))
(setq smode (getvar 'selectsimilarmode))
(setvar 'cmdecho 0)
(setvar 'osmode 0)
; MULTIPLE WIPEOUT
(princ "\nSelect items: ")
(setq sset (ssget '((0 . "LWPOLYLINE"))))
(if sset
(progn (setq n (1- (sslength sset)))
	(setq countn -1)
	(while (< countn n)
		(setq countn (1+ countn))
		; HELP HERE
		; TWO THINGS HERE.
		; 1. How can I get the pause to be only asked once in the while loop.
		; 2. Unknown command "MW".  Press F1 for help. comes up for the last 2 commands.
			(command "._wipeout" "_polyline" (ssname sset countn) pause)
			(command "_.change" (ssname sset countn) "" "properties" "color" "T" "255,255,255" "")
			(command "DRAWORDER" (ssname sset countn) "" "back" "")
(princ "\Sorry, no closed lwpolylines selected. ")
(setq sset nil)
(*error* nil)
(vl-load-com)
Not an answer to your question, but have you ever thought of just using a truecolor white hatch rather than a wipeout? I've had oddities in the past with printing wipeouts. Also .. have you seen THIS?
I haven't had too much trouble with them with DWG to PDF.pc3
Thanks, I'll take a look at that. I'm learning LISP so this was just a little excerise that I got stuck on.
I had problem with printing wipeouts too, required me to install AutoCAD service pack 1 or 2 (don't remember) and everything was fine again.
Anyway.. quick fix:
(defun C:test ( / *error* SS oCol acDoc b c i e o )
 (defun *error* (m)
   (and c (setvar 'cmdecho c))
   (and oCol (vl-catch-all-apply 'vlax-release-object (list oCol)))
   (and m (princ m)) (princ)
 ); defun *error*
 (and
   (setq SS
     (ssget "_:L"
         (-4 . "<AND")
         (0 . "*POLYLINE")
         (-4 . "<NOT") (-4 . "<AND") (0 . "POLYLINE") (-4 . "&") (70 . 80) (-4 . "AND>") (-4 . "NOT>")
         (-4 . "AND>")
   (setq oCol (vla-GetInterfaceObject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar 'acadver) 1 2))))
     (vla-put-ColorMethod oCol acColorMethodByRGB) (apply 'vla-SetRGB (cons oCol '(255 255 255)))
     (setq b (strcat "_" (substr (progn (initget "Yes No") (cond ( (getkword "\nErase source plines? [Yes/No] <No>: ") ) ( "No" ) )) 1 1)))
   (setq c (getvar 'cmdecho)) (setvar 'cmdecho 0)
   (repeat (setq i (sslength SS))
     (setq e (ssname SS (setq i (1- i))))
     (command "_.WIPEOUT" "_P" e b)
     (cond
       ( (eq "AcDbWipeout" (vla-get-ObjectName (setq o (vlax-ename->vla-object (setq e (entlast))))))
         (vla-put-TrueColor o oCol)
         (command "_DRAWORDER" (ssadd e) "" "_B")
 (*error* nil) (princ)
); defun C:test
EDIT: Included Undomarks
Grrr beat me to it, but here are some comments on your code.
(defun c:mw (/ *error* acdoc cmde countn e n os smode sset s)
   (and acdoc (vla-endundomark acdoc))
   (and errmsg
   (setvar 'osmode os)
 (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
 (or (vla-endundomark acdoc) (vla-startundomark acdoc))
 (setvar 'cmdecho 0)
 (setvar 'osmode 0)			; MULTIPLE WIPEOUT
 ;; Moved selection into if statement .. look into filtering for closed polylines
 (if (setq sset (ssget '((0 . "LWPOLYLINE"))))
   (progn ;; Create empty selection set to add wipeouts to
   (setq s (ssadd))
   (setq countn -1)
   (while (< countn n)
     (setq countn (1+ countn))	; HELP HERE
				; TWO THINGS HERE.
     (progn ;; Use "" rather than pause
	    (command "._wipeout" "_polyline" (ssname sset countn) "")
	    ;; Check that the last item added is a wipeout
	    (if	(= "WIPEOUT" (cdr (assoc 0 (entget (setq e (entlast))))))
	      ;; Put wipeout in a selection set to send to back (assuming this is what you intended?)
	      (progn (ssadd e s)
		     ;; Removed command call and use entmod to make wipeout RGB white
		     ;; (command "_.change" (entlast) "" "properties" "color" "T" "255,255,255" "")
		     (entmod (append (entget e) '((62 . 7) (420 . 16777215))))
		     ;; Put on a wipeout layer .. ENTMOD is your friend
		     (entmod (append (entget e) '((8 . "Wipeout"))))
   ;; Take this out of the loop and send the whole selection set back
   (command "DRAWORDER" s "" "back")
 (setq sset nil)
 (*error* nil)
 (vl-load-com)
@Grrr, that's amazing thanks so much.
I'll try get my head around that.
@ronjonp, The reason for the pause was to ask the user whether or not to delete the original polys. But Grrr has that as a setq in that. I never even thought of that.
So this is an edited version of your code for a Y/N prompt to delete the org. polylines.
(defun c:mw (/ *error* acdoc cmde countn e n os smode sset s b)
	(and errmsg
	(setvar 'osmode os)
(setvar 'cmdecho 0)
   	(setq s (ssadd))
   	(setq countn -1)
   	(while (< countn n)
				; TWO THINGS HERE.
     	(command "._wipeout" "_polyline" (ssname sset countn) b)
	      (progn (ssadd e s)
 (setq sset nil)
 (*error* nil)
 (vl-load-com)
Cheers guys. :notworthy:
Here's a modified version of Lee's code to convert a selection set of closed polylines :)
;; Polygonal Wipeout  -  Lee Mac
;; RJP added multiple polyline selection & some layering
(defun c:pw (/ a b c l m p s)
 (initget "Yes No")
 (setq	b (cond	((getkword "\nErase source plines? [Yes/No] <Yes>: "))
	("Yes")
 (if (setq s (ssget '((0 . "LWPOLYLINE") (-4 . "&") (70 . 1))))
   (foreach a (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
     (cond
((= 0 (apply '+ (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 42 (car x))) (entget a)))))
 (setq l (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget a))))
 (setq l (cons (last l) l)
       p (apply 'mapcar (cons 'min l))
       m (apply 'max (mapcar '- (apply 'mapcar (cons 'max l)) p))
       c (mapcar '+ p (list (/ m 2.0) (/ m 2.0)))
 (entmake
   (append
     (list '(000 . "WIPEOUT")
	   '(100 . "AcDbEntity")
	   '(100 . "AcDbWipeout")
	   '(008 . "Wipeout")
	   (cons 10 (trans p 1 0))
	   (cons 11 (trans (list m 0.0) 1 0))
	   (cons 12 (trans (list 0.0 m) 1 0))
	   '(280 . 1)
	   '(071 . 2)
     (mapcar
       (function
	 (lambda (x) (cons 14 (mapcar '(lambda (a b c) (/ (- a b) c)) x c (list m (- m)))))
       l
 (and (= b "Yes") (entdel a))
((print "The polyline selected has arc segments and was skipped..."))
Probably the most efficent version for this routine - vanilla and works on other closed objects like circles/ellipses :
;;; Original Source:
;;; OB2WO (gile) -Gilles Chanteau- 10/03/07
;;; Creates a "Wipeout" from an object (circle, ellipse, or polyline with arcs)
;;; Works whatever the current ucs and object OCS
;;; http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/wipeout-with-arcs/m-p/786490#M12148
;;; Modification for multiple selection of closed objects (except SPLINE), that sets color of 255,255,255 to the wipeouts and sends their draworder to bottom
;;; Assembled by Grrr
;;; Credits - Gile, Lee Mac
;;; http://www.cadtutor.net/forum/showthread.php?104705-How-to-pause-for-user-input-in-while-and-run-more-than-1-command-call&p=705082#post705082
(defun C:Wipeouts ( / ent2ptlst MakeWipeout *error* acDoc )
 ;;; ENT2PTLST - Gile
 ;;; Returns the vertices list of the polygon figuring the curve object
 ;;; Coordinates defined in OCS
 (defun ent2ptlst (e / o d n lst plst prec)
   (if (= (type e) 'ENAME) (setq o (vlax-ename->vla-object e)) )
   (cond
     ( (member (cdr (assoc 0 (entget e))) '("CIRCLE" "ELLIPSE"))
       (setq d (/ (vlax-curve-getDistAtParam o (vlax-curve-getEndParam o)) 50))
       (setq n	0)
       (repeat 50 (setq lst (cons (trans (vlax-curve-getPointAtDist o (* d (setq n (1+ n)))) 0 (vlax-get o 'Normal)) lst)))
     ( (setq plst (vl-remove-if-not '(lambda (x) (or (= (car x) 10) (= (car x) 42))) (entget e)))
       (while plst
         (setq lst (cons (append (cdr (assoc 10 plst)) (list (cdr (assoc 38 (entget e))))) lst))
         (if (/= 0 (cdadr plst))
             (setq prec (1+ (fix (* 25 (sqrt (abs (cdadr plst)))))))
             (setq d
                   (if (cdaddr plst) (vlax-curve-getDistAtPoint o (trans (cdaddr plst) e 0)) (vlax-curve-getDistAtParam o (vlax-curve-getEndParam o)) )
                   (vlax-curve-getDistAtPoint o (trans (cdar plst) e 0))
                 prec
             (setq n 0)
             (repeat (1- prec)
               (setq lst (cons (trans (vlax-curve-getPointAtDist o (+ (vlax-curve-getDistAtPoint o (trans (cdar plst) e 0)) (* d (setq n (1+ n))))) 0 e) lst))
         (setq plst (cddr plst))
   lst
 ); defun ent2ptlst
 ;;; MakeWipeout creates a "wipeout" from a points list and the normal vector of the object - Gile
 (defun MakeWipeout (pt_lst nor / dxf10 max_dist cen dxf_14)
   (if (not (member "acismui.arx" (arx))) (arxload "acismui.arx") )
   (setq	dxf10 (list (apply 'min (mapcar 'car pt_lst)) (apply 'min (mapcar 'cadr pt_lst)) (caddar pt_lst) ) )
   (setq max_dist (float (apply 'max (mapcar '- (apply 'mapcar (cons 'max pt_lst)) dxf10))))
   (setq cen (mapcar '+ dxf10 (list (/ max_dist 2) (/ max_dist 2) 0.0)))
   (setq dxf14 (mapcar '(lambda (p) (mapcar '/ (mapcar '- p cen) (list max_dist (- max_dist) 1.0))) pt_lst) )
   (setq dxf14 (reverse (cons (car dxf14) (reverse dxf14))))
   (entmakex
     (append
       (list
         '(0 . "WIPEOUT")
         '(90 . 0)
         (cons 10 (trans dxf10 nor 0))
         (cons 11 (trans (list max_dist 0.0 0.0) nor 0))
         (cons 12 (trans (list 0.0 max_dist 0.0) nor 0))
         '(13 1.0 1.0 0.0)
         '(70 . 7)
         '(280 . 1)
         '(71 . 2)
         (cons 91 (length dxf14))
       (mapcar '(lambda (p) (cons 14 p)) dxf14)
 ); defun MakeWipeout
 (defun *error* (m)
 ); defun *error*
   (lambda ( / SS b wSS i e L n w )
     (and
       (setq SS
         (ssget "_:L"
           '(   (0 . "CIRCLE,ELLIPSE,*POLYLINE") ; doesn't quite work with "SPLINE"
             (-4 . "<NOT")
             (-4 . "<AND")
             (-4 . "AND>")
             (-4 . "NOT>")
         (setq b (= "Yes" (progn (initget "Yes No") (cond ( (getkword "\nErase source objects? [Yes/No] <No>: ") ) ( "No" ) ))))
         t
         (setq wSS (ssadd))
           (and
             (vlax-curve-isClosed e)
             (setq L (ent2ptlst e))
             (setq n (cdr (assoc 210 (entget e))))
             (progn (and b (entdel e)) t)
             (setq w (MakeWipeout L n))
             (entmod (append (entget w) '((62 . 7) (420 . 16777215))))
             (setq wSS (ssadd w wSS))
           ); and
         ); repeat
         (LM:movetobottom wSS)
         (sssetfirst nil wSS) ; for the demo
       ); progn
     ); and
   ); lambda
); defun
;; DrawOrderV1-2.lsp - Lee Mac :
;; Move to Top  -  Lee Mac
;; Moves a set of objects to the top of the draw order.
;; obs - [lst/sel] Selection set or list of objects with same owner
;; Returns: T if successful, else nil
(defun LM:movetotop ( obs / tab )
 (if (and (or (= 'list (type obs)) (setq obs (LM:ss->vla obs)))
   (setq tab (LM:sortentstable (LM:getowner (car obs))))
 (not (vla-movetotop tab (LM:safearrayvariant vlax-vbobject obs)))
;; Move to Bottom  -  Lee Mac
;; Moves a set of objects to the bottom of the draw order.
(defun LM:movetobottom ( obs / tab )
 (not (vla-movetobottom tab (LM:safearrayvariant vlax-vbobject obs)))
;; Move Above  -  Lee Mac
;; Moves a set of objects above a supplied object in the draw order.
;; obj - [vla] Object above which to move supplied objects
(defun LM:moveabove ( obs obj / tab )
 (not (vla-moveabove tab (LM:safearrayvariant vlax-vbobject obs) obj))
;; Move Below  -  Lee Mac
;; Moves a set of objects below a supplied object in the draw order.
;; obj - [vla] Object below which to move supplied objects
(defun LM:movebelow ( obs obj / tab )
 (not (vla-movebelow tab (LM:safearrayvariant vlax-vbobject obs) obj))
;; Swap Order  -  Lee Mac
;; Swaps the draw order of two objects (may require regen).
;; ob1,ob2 - [vla] Objects to swap
(defun LM:swaporder ( ob1 ob2 / tab )
 (if (setq tab (LM:sortentstable (LM:getowner ob1)))
   (not (vla-swaporder tab ob1 ob2))
;; Get Owner -  Lee Mac
;; A wrapper for the objectidtoobject method & ownerid property to enable
;; compatibility with 32-bit & 64-bit systems
(defun LM:getowner ( obj )
 (eval
   (list 'defun 'LM:getowner '( obj )
     (if (vlax-method-applicable-p obj 'ownerid32)
       (list 'vla-objectidtoobject32 (LM:acdoc) '(vla-get-ownerid32 obj))
       (list 'vla-objectidtoobject   (LM:acdoc) '(vla-get-ownerid   obj))
 (LM:getowner obj)
;; Catch Apply  -  Lee Mac
;; Applies a function to a list of parameters and catches any exceptions.
(defun LM:catchapply ( fnc prm / rtn )
 (if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply fnc prm))))
   rtn
;; Sortents Table  -  Lee Mac
;; Retrieves the Sortents Table object.
;; obj - [vla] Block Container Object
(defun LM:sortentstable ( obj / dic )
 (cond
   (   (LM:catchapply 'vla-item (list (setq dic (vla-getextensiondictionary obj)) "acad_sortents")))
   (   (LM:catchapply 'vla-addobject  (list dic "acad_sortents" "AcDbSortentsTable")))
;; Selection Set to VLA Objects  -  Lee Mac
;; Converts a Selection Set to a list of VLA Objects
;; sel - [sel] Selection set (pickset)
(defun LM:ss->vla ( sel / idx lst )
 (if (= 'pickset (type sel))
   (repeat (setq idx (sslength sel))
     (setq lst (cons (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) lst))
;; Safearray Variant  -  Lee Mac
;; Returns a populated safearray variant of a specified data type
;; typ - [int] Variant type enum (e.g. vlax-vbdouble)
;; lst - [lst] List of static type data
(defun LM:safearrayvariant ( typ lst )
 (vlax-make-variant
   (vlax-safearray-fill
     (vlax-make-safearray typ (cons 0 (1- (length lst))))
     lst
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
 (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
 (LM:acdoc)
(vl-load-com) (princ)
Thanks to Gile and Lee Mac! :)
Although it errors out on closed splines (maybe I should have used LM:EntityToPointList).
I'll be sure to give that a go. !
BTW, This might be a bit off topic but it relates to closed/open polylines.
Sometimes/Most of the time 🤦 I get polylines that are closed but with 2 or more verts on top of each other. Is there any routine you guys know to combat this?
Sometimes/Most of the time I get polylines that are closed but with 2 or more verts on top of each other. Is there any routine you guys know to combat this?
Look for gile's simplifypoly routine (somewhere on theswamp).
Does he have the nick CAB? This one?
http://www.theswamp.org/index.php?topic=19865.msg244786#msg244786
Anyway, it works a treat.
OVERKILL never fix these.
Just downloaded Polyline Diet yesterday too which is great variation too.
http://cadtips.cadalyst.com/linear-objects/polyline-diet
EDIT:
Found it: http://www.theswamp.org/index.php?topic=19865.msg244892#msg244892
Wow, this is amazing. Thank you!!
Edited by 3dwannab
