Select some blocks and Connecting by arc or pline
hosyn
Basically, I want to be able to select some blocks and have a joined polyline with arcs connecting the insertion points via closest distance between blocks.
Change points data with block insertion points... Actually both are DXF 10, so just replace in (ssget) from "POINT" to "INSERT"... Ooops, just saw everything is fine (ssget) has "INSERT,CIRCLE"...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-draw-polyline-across-multiple-center-points/td-p/8038549
M.R.
