+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Forum Newbie
    Using
    AutoCAD 2016
    Join Date
    Jul 2018
    Posts
    2
    Default Simplifying lwpolyline to arcs
    Hello everyone, band new to the forum and a novice with Autocad. I am working in Autocad 2016, trying to prepare artwork to be laser cut in steel. My linework is fairly intricate, lots of small contours. I have produced a smooth lwpolyline but my cutter says that importing it to his cam software makes it all jagged and unusable. He says I need to trace the lwpolyline by hand with pure arcs and minimum vertices. I know there must be a straight forward way for the software to do this for me. I have tried the WEED lsp but it does not work with lwpolyline. I tried OVERKILL just in case but there are no redundancies, just too many points. I have been trying to go the POTRACE route, taking a bitmap image and trying to render simple curves with Selig's application but I cannot seem to get the commands to work (operator error I'm sure). I am looking for any guidance you can offer, in kind of a desperate spot. I have hundreds of objects that need to be processed so it is a very intensive option to hand trace it all. I keep reading about the Polyline Diet lsp but I cannot find a downloadable lsp file anywhere.
    HELP, please!
  2. #2
    Forum Newbie
    Using
    AutoCAD 2016
    Join Date
    Jul 2018
    Posts
    2
    Default found pldiet.lsp! it helps but cannot get it to keep smooth curves
    I installed the pdiet lsp and it helps quite a bit. I am attaching a file that shows the original lwpolyline along with two reduced versions after applying PLD with different parameters. Advice on getting smoother curves with longer spans between points?
Similar Threads
  1. Draw a new lwpolyline passing through points inner existing lwpolyline.
    By Kowal in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2017, 10:18 am
  2. Need Help Simplifying Polylines
    By Blared in forum AutoCAD General
    Last Post: 17th Jul 2015, 04:21 pm
  3. Flatten and simplifying geometry.
    By Impact in forum AutoCAD General
    Last Post: 7th Dec 2010, 10:26 pm
  4. simplifying polylines
    By mossieramm in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jul 2009, 11:09 am
  5. Simplifying 3D Faces?
    By Wizzel in forum AutoCAD General
    Last Post: 29th Jul 2007, 08:45 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
