DIMREASSOCIATE command is not REGEN'ing the X point of the dim node.
3dwannab
See gif.
I'm after learning about the DIMREGEN command after pulling my hair out while dim'ing in PS with an xref'd model. SO,
When I run the command DIMREASSOCIATE.
The X to show the old pick point of the dim appears if it's currently in view. But if it's not it doesn't. Only if I right click and enter pan mode the X appears if it's on screen.
Really frustrating because I don't want to redo them.
The applicable vars set that I think would work:
REGENMODE = 1
REGENAUTO = ON
LAYOUTREGENCTL = 2
Using R23.0 (2019)
Edited by 3dwannab
changed gif to external link
