wimal Posted July 24, 2018 Share Posted July 24, 2018 In my drawing lines cant draw with coordinates. But when I pick points it can draw. Block cant insert to given points typing coordinates. But if I pick a point it can insert. Same file working properly in others PCs. Please help. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted July 24, 2018 Share Posted July 24, 2018 Do you mean that you can't type in coordinates such as 1042.85,65428.1606 ? Are you entering them in the format of X,Y? Are you entering coordinates outside the LIMITS? Quote Link to comment Share on other sites More sharing options...
wimal Posted July 26, 2018 Author Share Posted July 26, 2018 Do you mean that you can't type in coordinates such as 1042.85,65428.1606 ?Are you entering them in the format of X,Y? Are you entering coordinates outside the LIMITS? Yex I am entering as X,Y and the point is inside the limits. Quote Link to comment Share on other sites More sharing options...
eldon Posted July 26, 2018 Share Posted July 26, 2018 Have you checked your OSNAPCOORD system variable? Quote Link to comment Share on other sites More sharing options...
wimal Posted July 31, 2018 Author Share Posted July 31, 2018 Finally I found the solution. Press F12 or off the dynamic input button. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 31, 2018 Share Posted July 31, 2018 If you want to use Dynamic Input and still enter coordinates, set the appropriate Value for DYNMODE. Quote Link to comment Share on other sites More sharing options...
