+ Reply to Thread
Results 1 to 4 of 4
Thread: Cad File Naming
  1. #1
    Forum Newbie
    Using
    AutoCAD LT 2014
    Join Date
    Aug 2014
    Posts
    5
    Default Cad File Naming
    I work in a company that has thousands of autocad .dwg files in a folder with unique names. The .dwg files are published to a Print folder as a PDF file using the same name as the .dwg file.
    When we make a revision to a drawing we do not add the revision to the file name. I am thinking that we should add the revision level to the file names in our database. Therefore, whenever a revision is made, the file name of the .dwg and .pdf file are changed to show the new revision. Is this a good file naming convention?
  2. #2
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,800
    Default
    We do revisions as part of filename few thousand dwg's. We also do not use random names rather have a index for projects that gives us the dwg number, we do these by year 2018001 2018002 etc. I think I saved it as barney rubbles garage can not find it now. Use even excel.
  3. #3
    Senior Member
    Computer Details
    Handiman's Computer Details
    Operating System:
    (W) Win 10, x64 / (H) Win 7 Prof. x64
    Computer:
    (W) Custom / (H) Custom i5
    Motherboard:
    (W) Asus X99-A II / (H) ASUS P8Z7- V Pro
    CPU:
    (W) i7-6800K (H) i5-3570K
    RAM:
    (W) 32GB (H) 32GB
    Graphics:
    (W) GTX-1070 (H) Quadro K4000 & GeForce 660ti
    Primary Storage:
    (W) 950 Pro 512GB SSD (H) 256GB, 60GB SSD's
    Secondary Storage:
    (W) 850 Pro SSD, 1TB platter (H) 3 TB 7200Rrpms
    Monitor:
    (W) Dual ASUS 27" (H) Dual ASUS 27" MX-279H
    Discipline
    Manufacture
    Handiman's Discipline Details
    Occupation
    Detailing/Designing Stair handrails, Illuminated & Non-Illuminated
    Discipline
    Manufacture
    Details
    Handrails for Commercial and Residential Illuminated and Non-Illuminated (LED mostly)
    Using
    AutoCAD 2018
    Join Date
    May 2012
    Location
    Dallas TX
    Posts
    100
    Default
    At a past company when we had a revision we would add to the end of the file name RevA or B or what the revision was then we also had a folder labeled "OLD FILES" for the previous files (Revisions)
    Be aware it can eat up server space quickly as you now have multiple files of the same size. IT was not happy with our file format.
    Good Luck
  4. #4
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,154
    Default
    In our AutoCAD days, we did it this way:
    1. The main DWG file is always the "current revision".
    2. When a revision is expected, we copy/paste the current file into another folder as an archive, in which we put a suffix on the end of the file name identifying the current revision.
    This way things keep flowing but we could always go back if need be. So the first time we have a revision, the current DWG file got copied and the suffix is "Original". Second revision, current DWG file got copied with a suffix "Revision 1". We just kept the main file current, copying as necessary for a record snapshot of the previous revision or phase. We felt that always worked out best for our company standards.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
Similar Threads
  1. Revit File Naming Conventions
    By resullins in forum Revit General
    Last Post: 2nd Sep 2016, 04:47 pm
  2. File Naming/Management
    By RobDraw in forum CAD Management
    Last Post: 9th Jun 2014, 12:19 pm
  3. Plot to PDF File Naming Convention
    By Flyers28 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jul 2013, 07:11 pm
  4. File naming conventions:
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 7th Jan 2009, 11:56 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
