Robson Posted August 4, 2018 Share Posted August 4, 2018 Hello, I want to create a standard drawing (example a rectangle with the dimensions of length and width), but the values of the dimensions should be obtained in a result of a formula of an excel cell. How can I do this? I have only seen how to import and export entire worksheets, but what I need are specific cell values. rggomes@gmail.com Quote Link to comment Share on other sites More sharing options...
Cleyton Ramos Posted November 2, 2018 Share Posted November 2, 2018 Hello! Do you want to import from excel to AutoCad and AutoCad to Excel? It is ? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 8, 2018 Share Posted November 8, 2018 It is achievable and there is lots of examples out there, you can read individual cells so get length and width and draw a rectang. Now the excel answer is just make a rectang command and copy and paste the result to the command line. rectang x1,y1 x2,y2 you just use the concatenation command in excel. The only real question here is what does your excel spreadsheet look like you have to have some way of knowing which cell to read. Do a search here 1st for “excel” If you provide a sample Xl then someone may have something. Quote Link to comment Share on other sites More sharing options...
