Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Super Member
    AutoCAD 2010
    Dec 2010
    1,246
    Default File handling : reading text file
    Hi,
    Its been a while since I lisp, trying to go back to track
    The lisp should acquire the drawing database for specific layers and ones they are found it should set a specific color to them.
    The lisp should read an external txt file containing the layer name and color to set, in this format (layerName,11).
    Ive saved the text file, lisp,dwg at the same folder, and use this code
    Code:
    (setq file (open "map.txt" "r"))
    (read-line file)
    (close file)
    ; error: bad argument type: FILE nil
    it seems like lisp cannot find the file , even if i use absolute file path it wont be found
    Help please
    shay
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,106
    Code:
     (if (and (setq fn (findfile "map.txt"))
              (setq fp (open fn "r"))
       (progn (setq data (read-line fp))(close fp))
       (princ "\nUnable to find or open map.txt")
    Super Member
    AutoCAD 2010
    Dec 2010
    1,246
    Quote Originally Posted by rlx View Post
    Code:
    it return nil
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,567
    What does this return for you?
    Code:
    (defun c:test ( / des str txt )
        (cond
            (   (not (setq txt (findfile "map.txt")))
                (princ "\nmap.txt not found.")
            (   (not (setq des (open txt "r")))
                (princ "\nmap.txt could not be opened for reading.")
            (   (princ "\nmap.txt found and opened for reading.")
                (setq str (read-line des))
                (princ "\nRead 1 line from map.txt: ")
                (princ str)
                (close des)
                (princ "\nmap.txt closed.")
        (textpage) (princ)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,246
    Hi
    Im writing a program that manipulate layers by a given text file
    The text file might look something like :
    Code:
    window,11
    wall,144
    my program will do the following:
    1. Open the file
    2. Read until it get to “,” (as <layer name>)
    3. Read after the “,”(as <color>)
    4. Look layers for <layer name>
    5. Set <color> as the layer color
    6. Loop til the end of file
    how do i perform number 2 and 3?
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,567
    Quote Originally Posted by samifox View Post
    Typically, you might use a function such as vl-string-position or vl-string-search to determine the position of the comma within the string, and then use substr with the appropriate index arguments to obtain the string either side of the comma; or alternatively, use list functions such as nth/car/cadr on the list returned by a function such as my String to List function.
    However, since you are using comma delimiters, you could also use DIESEL to obtain the data either side of the comma:
    Code:
    _$ (setq str "MyLayer,MyColour")
    "MyLayer,MyColour"
    _$ (menucmd (strcat "m=$(index,0,\"" str "\")"))
    "MyLayer"
    _$ (menucmd (strcat "m=$(index,1,\"" str "\")"))
    "MyColour"
  7. #7
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    it return nil
    Does your file actually exist and has it the data you describe? If so
    Code:
     (princ data)
    should return the first line in the file.
  8. #8
    Super Member
    AutoCAD 2010
    Dec 2010
    1,246
    this is the code ive come to so far,
    its trow an error
    please help
    Code:
    (defun tst (/ txt des str layer color l)
      ;; reading...
      (close des)
      ;; divide string by comma
      (setq layer (menucmd (strcat "m=$(index,0,\"" str "\")")))
      (setq color (menucmd (strcat "m=$(index,1,\"" str "\")")))
    ;;set layer color
      (setq l (tblobjname "LAYER" layer))
      (setq l (vlax-ename->vla-object l))
      (vlax-put-property l 'Color color)
      (vl-load-com)
  9. #9
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,261
    Hi,
    You can use my function below to separate a string with delimiter.
    Code:
    (defun _peelstring (string del / str pos lst)
      ;; Tharwat - 03.Mar.2015	;;
      (while (setq pos (vl-string-search del string 0))
        (setq str    (substr string 1 pos)
              string (substr string (+ pos (1+ (strlen del))))
        (and str (/= str "") (setq lst (cons str lst)))
      (and string (/= string "") (setq lst (cons string lst)))
      (reverse lst)
    usage f the above function:
    Code:
    _$ (_PEELSTRING "Layer1,Color,Ltype,LineWeight" ",")
    ("Layer1" "Color" "Ltype" "LineWeight")
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    just quickly written , change path to match and make sure names and colors in your data file are correct
    Code:
    (defun c:samifox ( / actDoc fn-data-file fp-data-file data-list )
      (vl-load-com)
      (setq actDoc (vla-get-activedocument (vlax-get-acad-object))
            fn-data-file (findfile "d:\\Temp\\Lisp\\Cad-tutor\\samifox\\map.txt"))
      (cond
        ((null fn-data-file)
         (princ "\nData file map.txt not found"))
        ((not (setq fp-data-file (open fn-data-file "r")))
         (princ "\nUnable to read from map.txt"))
        (t
         (while (setq data (read-line fp-data-file))
           (if (setq pos (vl-string-position (ascii ",") data))
             (setq data-list (cons (cons (substr data 1 pos) (substr data (+ 2 pos))) data-list))
      ; data integrity test
      (cond
        ((not (vl-consp data-list))
         (princ "\nNo usable layer data was found"))
        (t (mapcar 'fox-it data-list))
    (defun _AddLayer ($lay)
      (if (vl-catch-all-error-p (setq $lay (vl-catch-all-apply 'vla-add (list (vla-get-layers actDoc) $lay)))) nil $lay))
    (defun fox-it ( x / lay col l)
      (setq lay (car x) col (cdr x))
      (if (not (tblsearch "layer" lay)) (_AddLayer lay))
      (if (setq l (tblobjname "LAYER" lay))
        (progn (setq l (vlax-ename->vla-object l)) (vlax-put-property l 'Color col))
  1. Reading .DWG file with vb.NET
    By DB007 in forum .NET, ObjectARX & VBA
    Last Post: 25th Sep 2016, 12:50 pm
  2. reading text file with characters (~, ',')
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Sep 2013, 08:36 pm
  3. Handling Drawing (DWG) File Format Changes with AutoCAD
    By HyperPics in forum AutoCAD RSS Feeds
    Last Post: 5th Jul 2012, 09:40 pm
  4. Need help in reading data file
    By T2L in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jun 2009, 09:55 pm
