conversion of dxf file to pse
gotchy
Will one of the Gurus here explain the procedure tor converting a dxf file drawn in AutoCAD into a pse file. The pse file is to be used in a laser engraver. The laser engraver will not recognize a dxf file.
Thank you,
Andrew
