Bob658 Posted August 13, 2018 Share Posted August 13, 2018 I'll try and keep this simple. I have 3 files. In file A is base information. In file B is an xref of file A. Whilst in file B I have changed the appearance of file A by switching layers off and changing layer colours and linetypes. I then create file C and xref file B into file C. However, all the information relating to file A reverts back to how it is set in its original file and not as I changed it in file B. How do I get it to automatically show the xref of file A to be the same as the changes in file B when I xref B into file C? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted August 14, 2018 Share Posted August 14, 2018 Check your system variables VISRETAIN, VISRETAINMODE, and XREFOVERRIDE. If that doesn't help, we may need more information. Quote Link to comment Share on other sites More sharing options...
Bob658 Posted August 14, 2018 Author Share Posted August 14, 2018 I have tried the system variables you highlighted but to no avail. I have attached 2 files to try and help explain a bit better. File A contains the information I receive and I don't edit. I xref file A into file B and use the layer table to make adjustments. This forms my base model. I then xref file B into other files (file C etc.) from which I plot. However when I xref file B into file C it doesn't take through the changes I made to the layer table in file B. What I want is for the changes made to the layer table in file B to be carried through to file C automatically. File A.dwg File B.dwg Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted August 15, 2018 Share Posted August 15, 2018 Take a look at this page. You can modify layer settings for drawing A in drawing B, but those changes don't propagate to drawing C. Bug or feature? You decide. So their solution is to save the layer state in A and load it into C. Here's another page. If you change all the layers in drawing A to one color (one command), you can grey them out. Quote Link to comment Share on other sites More sharing options...
