Bobzy20 Posted August 14, 2018 Share Posted August 14, 2018 Hi I have some text in AutoCAD that are sitting at all different degrees, I would like to run a script to basically keep the text where it is but reset the rotation angle back to 0. Does anybody know of such a thing that already exists? Thanks Bob Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 14, 2018 Share Posted August 14, 2018 Have you tried filter then properties and just set text angle to 0.0 Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted August 14, 2018 Author Share Posted August 14, 2018 Thanks, I haven't but I will try it and get back to you. Bob Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted August 14, 2018 Author Share Posted August 14, 2018 I have attached the DWG file with the text, as I wasn't sure how to do what you suggested. Test.dwg Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 14, 2018 Share Posted August 14, 2018 Are you wanting to rotate all the objects? Your initial question only mentions text. Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted August 15, 2018 Author Share Posted August 15, 2018 I want to reset the rotation value to 0 but keep everything in the same place. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 15, 2018 Share Posted August 15, 2018 Hi, Try this. (defun c:Test ( / int sel ent ) (and (setq int -1 sel (ssget "_:L" '((0 . "*TEXT") (-4 . "/=") (50 . 0.0)))) (while (setq ent (ssname sel (setq int (1+ int)))) (entmod (append (entget ent) '((50 . 0.0)))) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
eldon Posted August 15, 2018 Share Posted August 15, 2018 I manually set the rotation of the text to zero degrees, and this is what I got. Is it really what you want? The text seems to be generated backwards and upside-down, but it is in the same place. Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted August 15, 2018 Author Share Posted August 15, 2018 The text was part of an attribute block which I would have copied/rotated/aligned around the drawing, I would have flipped the text up side down and backwards using the Enhanced Attribute Editor to suit my needs. When I import it into our bespoke graphical software, its throwing the text out. I think I will need to go back into the Enhanced Attribute Editor and uncheck the backwards & up side down options and then rotate the text to a normal rotation angle, its currently at an angle of 202 but if I go to a rotation angle of 22, it seems to work ok. Sorry and thanks for your help on this Bob Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 15, 2018 Share Posted August 15, 2018 Hi Bob, Did you see my post above? Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted August 15, 2018 Author Share Posted August 15, 2018 I did see it thanks and it worked great. I need to spend some time on it and figure out what the issue is. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 15, 2018 Share Posted August 15, 2018 You are most welcome. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 16, 2018 Share Posted August 16, 2018 The fix may be in a block you can have align text to layout this will say text set to 0 will do just that and not go upside down. Quote Link to comment Share on other sites More sharing options...
